Weekend Brake Job....
2006 C230SS & 2009 E350
A very productive weekend, I replaced the front rotors and pads, and rear pad. Then I flushed the brake fluid. Btw, thanks to Brenden (paypaboy) for the hook up on R1 brakes.
![](http://farm4.static.flickr.com/3573/3453957361_0b2eb20197_b.jpg)
![](http://farm4.static.flickr.com/3405/3454775296_2508f850cb_b.jpg)
im doing the same thing in a few weeks...do you have any more pics on the ordeal or info? how come you didnt replace the rear rotors? did you need to replace the front rotors or did you just decide to get the R1 rotors? amd what pads did you use?
Next time please observe that the jack is a tire changing tool only. Don't endanger yourself, others, and your car by working on it while sitting on the tire jack. Spend the money on a real jack, and some stands to support the car while working on it.
I will assume that you bought brake fluid from a dealer, because the correct fluid is not available from the aftermarket in the US except in Mercedes packaging. You run a risk of damage to the ABS system if the wrong fluid is used.
The pressure bleeder is a great tool, but I did not see two very necessary tools in your pictures. The first is a piston resetting tool. The correct tool uses parallel plates to push the piston back into the caliper without canting it. If the piston is not pushed straight back it will always damage the seal and can scratch the bore or the piston. The other tool is a torque wrench to properly set the fastener stretch on the rotor, caliper, and wheel. Don't risk an accident because you didn't have a $ 100 tool.
Congrats on doing your own brakes. You now have about $ 700 to spend on yourself.
Is @ Home
Torque wrench isn't necessary, recommended yes but most don't bother with it.
Please watch the video below. This a fella who felt he knew more than the engineers, and felt a torque wrench "isn't necessary."
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
http://www.youtube.com/watch?v=jv4m41viy4I
Is @ Home
How about a flat piece of board in conjuncture to the plier clamp? That should work.
The RX7 video was found to be issues with the incorrect lug nuts, it was the only thing the FD boards were posting at the time when I still had my RX7.
IF the clown in the RX7 had used a torque wrench on the wheel nuts, he would have discovered the incorrect parts before he crash landed his car.
I do, but there are lots of pictures in the brake DIY thread. Please let me know if you have any specific questions, maybe I can help. Front rotor already reached the min thickness, and rear rotors still have plenty. I have R1 rotors, and posi quiet pads. So far, it seems that it has less dust than stock pad.
Andy
also do their rotors go the correct direction or did they follow the same lazy pattern MB did by using only one rotor and applying it to both sides of the vehicle?
That is not a C-clamp, that is a locking plier clamp. Used mostly by welders to clamp work pieces in place. It does not have a parallel jaw, it will cant the piston and lead to a leaky caliper.
Please watch the video below. This a fella who felt he knew more than the engineers, and felt a torque wrench "isn't necessary."![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Wow, I never use a torque wrench what should the bolts be torqued at does anyone know?
MBworld Guru
white and whiter
i don't use a torque wrench. the only time i had problem with it was when someone attempted to steal my wheel.
LMFAO at the RX7. first time seeing that video. I don't think owning a torque wrench would've helped.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Super Moderator
2007 C230SS; 2014 ML350 BT
![](http://www.samstagsales.com/images/kk126-00.jpg)
Samstag Sales wants $189.99 for that tool. Got a link for a more reasonably priced one?
Actually, I like SlvrC230SS choice of piston compression tool. The ends of the clamp swivel and can conform to an uneven surface (like the swivel pad on a c clamp) at one end much better than a fixed arm tool. As long as you center it over the piston and use something as a buffer (the worn pad is great for this as mentioned) there should be no problem. The vice grip tension is smooth and more easily controlled than a screw clamp IMHO. I've seen the screw type do some real damage...obviously not used correctly. Until my arthritis starting getting bad I just pushed them in with my hands. With the bleeder valve open it's very easy, harder with it closed.
