Two reverse gears
Old Apr 20, 2009 | 12:26 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
Two reverse gears
So I read on here that the 7G tronic has 2 reverse speeds, so I tried accelerating in reverse in an open parking lot. I never felt a shift... is it just one ratio for S and one for C mode?
Old Apr 20, 2009 | 12:35 PM
W203E35's Avatar
2006 C350 Sport 6MT
Huh pretty interesting. Long story short I passed this car with emergency on. I felt bad so I put my car in reverse went reverse no kidding maybe 40MPH. I did feel a shift and I thought I was imagining things. I did feel this wierd shift. althought I have been having transmission problems that is why I may have felt it.
But I was going around 40MPH on S not C
Old Apr 20, 2009 | 01:07 PM
Found it on page 7 of this:
http://www.mercedestechstore.com/pdf...9%20062504.pdf
its indeed a different ratio for S and C. I dont think it shifts on the fly.
Old Apr 20, 2009 | 01:25 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Correct. It's only C vs. S or on my car
S vs. W.
Summer or winter.
Sometimes I use the W for backing up my driveway so the wheels don't spin.
Old Apr 20, 2009 | 05:10 PM
Glyn M Ruck's Avatar
Super Moderator
Not correct. The 7G will shift up in reverse in S & not in C
Old Apr 20, 2009 | 05:25 PM
Super Moderator
This is not what it says in the above pdf so it's either profiled differently in different markets or they have changed to on the fly shifting in sport post the time the above was written
Old Apr 20, 2009 | 06:00 PM
acr2001's Avatar
2012 C300 4Matic
Even the 5 speed has two reverse gears. They've had that feature forever. Not sure if it shifts through them though. I know the starting reverse gear depends on S or C. I don't think it really matters if it shifts while in reverse! Unless maybe you're doing some *insane* James Bond ****!
Old Apr 20, 2009 | 06:02 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Reversing in C mode + throttle lag = epic fail anyway. Assuming it's normal weather.
Old Apr 20, 2009 | 06:03 PM
Super Moderator
Yeah acr - agreed - no the 722.6 5 speed won't shift on the fly
Old Apr 20, 2009 | 06:25 PM
Utahkompressor's Avatar
W124, W203, W204, W251
The transmission actually has the capability of 7 reverse ratios.....it's just the valve body and electronic control that prevent 7-speed reverse. And....5-speed unit also have two reverse ratios like acr2001 said
Old Aug 1, 2023 | 03:05 PM
bernmeister's Avatar
w211 E320
Angry Long term follow up.
I have tried everything, S, C, D but not high speed reverse. No signs of a different ratio or shift. Has anybody got a definite answer to the 2 reverse gear question?
