Need a new car/help finding one
Alfa Romeo 164L
The car I've been looking at lately is a '00 '01 C240 just because my friend has one but I love it.
My question is, is this a good Mercedes to be looking at? What problems may I come across with this model and would it be worth it to own. Also maybe any other advice anyone could give me on getting another type of MB
Also if this helps I am a college student but just love MB. My last car was a 1985 Mercedes-Benz 190e 2.3-16v Euro Spec until I totaled it. The car saved my life and I can't imagine driving any other vehicle thats why I'm sticking with MB.
02 C320 Sedan
Weatherstripping drivers door 100 dollars
Center console were it says park N drive ETC.. well a clip broke on the bottom of that don't ask me how.. 140 dollars
Stepper motor clips just broke ????
New battery 150
New brakes new pads $$$$???
Im only 20 when i was working this car was easy cake to pay for.. But now i have other ways to pay for my car muahahaha
Here is issues with a 2001
2001 C240 Sedan
General Recalls
TSB Number & Issue Date TSB Title
2000110005 DEC 00 Campaign - Accelerator Pedal Value Sensor, Failure
Service Bulletins
P-27_55-50A FEB 05 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
P-72_29-39A JAN 05 Body - Front Power Window Motor Locks Up When Closing
P-82_10-398A JAN 05 Lighting - License Plate Bulbs Burned Out
P-54_21-133 JAN 05 Lighting - Trunk/Cargo Light Inoperative
P-54_21-121 JAN 05 Lighting - Brake/Park Lamps Flicker With Engine ON
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_21-124 DEC 04 Lighting - Headlamps/IP Lamps Flicker
P-54_21-126 DEC 04 Power Locks - Central Locking System Inoperative
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-54_21-119 OCT 04 Lighting - Tail/Brake Lamps ON Continuously
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
P-72_00-33 SEP 04 Body - Front/Rear Window Knocking Noise When Operated
P-82_10-376 SEP 04 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
P-82_62-391 SEP 04 Audio System - Comes ON at Maximum Volume
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-82_20-370 SEP 04 Lighting - Dome Lamp Won't Come On
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-68_20-29 AUG 04 Interior - Console/Armrest Lid Rubbing Noise
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-65B JUL 04 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
P-77_20-26 JUL 04 Body - Sliding Roof Excess Lift Control Feature
P-68_50-24 JUN 04 Interior - Sunblind Chafe Guard/Loose
P-83_40-71 APR 04 Climate Control - Heating and Cooling Set-Points
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-33_10-11 APR 04 Suspension - Rumbling Noise Driving Over Rough Roads
S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-18_00-20 DEC 03 Engine - Oil Sludging Damage/Class Action Settlement
T-18_00-21 DEC 03 Engine - Oil Sludging/Consumption Diagnosis & Repair
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-62_00-06 SEP 03 Body - Water Leaks Into Front Footwells
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-80_57-24 SEP 03 Drive Authorization System (DAS) - Component Diagnosis
P-32_20-17A JUL 03 Suspension - Front End Knock/Rumble on Rough Roads
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-195C JUL 03 Lighting - Front Turn Signals Inoperative
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-46_20-10 FEB 03 Steering Rack - Connector Leaks
P-82_10-217 JAN 03 Lighting - Parking/Tail Lamp Bulbs Inoperative
P-32_25-13 JAN 03 Suspension - Rumbling Noise From Rear Axle Area
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
P-26_50-01 SEP 02 M/T - Assembly Precautions/Recommendations
P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
P-91_60-53 JUL 02 SRS System - SRS Lamp ON/DTC's B1058/B2DB0
P-18_40-18A JUL 02 Engine Controls - 'Engine Oil Level Above Max' Displayed
P-82_95-164A JUL 02 Keyless Entry - Tele Aid(R) Remote Unlocking Inoperative
P-68_20-14 MAY 02 Interior - Front Cup Holder Broken
P-32_20-10 APR 02 Suspension - Rear Axle Noise
P-80_35-16 APR 02 Interior - Seat Memory Key Assignment
P-47_10-25 APR 02 Instruments - Erratic Fuel Gauge Operation
2001100003 MAR 02 Campaign - ESP Module Ground Connection Inspection
P-47_10-24 FEB 02 Fuel System - Fuel Sender Identification
P-07_60-16 JAN 02 Engine Controls - Rough Idle/Hesitation/DTC's Set
P-83_30-58 JAN 02 Automatic Temperature Control - Inoperative
P-82_85-182 DEC 01 COMAND(R) System - Various Malfunctions
P-82_85-181 NOV 01 COMAND(R) System - Does Not Respond to Voice Controls
P-83_00-57 NOV 01 A/C - Windshield Fogging in Center
P-47_20-20 NOV 01 Fuel System - Replacement Fuel Pump Adapter Harness
P-80_30-13 NOV 01 Smart Key(R) - Download Time
P-82_64-175 OCT 01 Audio System - CD Changer Static/Interference
P-47_20-17 OCT 01 Fuel System - Hard Start After Fuel Filter Replacement
P-27_60-34 OCT 01 Brakes - Fault Code P2000 Explanation
P-40_10-33A OCT 01 Tires - Approved Winter/Summer Tires
P-82_62-168 SEP 01 Audio System - Poor AM/FM Band Reception
P-82_62-165 SEP 01 Audio System - Popping/Thumping From Speakers
P-82_85-170 SEP 01 COMAND(R) System - Incorrect ETA Calculation Displayed
P-82_85-171 SEP 01 COMAND(R) System - Instrument Display Not Centered
P-32_25-07 SEP 01 Suspension - Front Axle Thumping Noise on Rough Roads
P-80_57-12 AUG 01 Smart Key(R) - Intermittently Inoperative
P-80_57-11 AUG 01 Ignition System - Electronic Ignition Switch Replacement
P-91_10-50A AUG 01 Interior - Noises From Front Seat Tilt Mechanism
P-07_65-14 AUG 01 Engine Controls - Rough Idle After Coming to a Stop
P-91_10-51 AUG 01 Interior - Front Seat Head Restraint Rattles
P-77_20-14 AUG 01 Body - Panorama Roof Panel Won't Open or Move
P-88_50-24 AUG 01 Body - Trunk Lid Will Not Open
P-91_60-48 AUG 01 Air Bag System - Side Impact Sensor Replacement
P-47_30-15 AUG 01 Emissions - OBD Shut-Off Valve Clicking Noises
P-68_10-12 AUG 01 Body - Noises From Right A-Pillar Area
P-62_10-02 AUG 01 Body/Cooling System - Upper Radiator Mount Bolts Break
P-47_25-14 AUG 01 Emissions - Evaporative Purge Valve Ticking Noise
P-72_10-21 JUL 01 Body - Door Hinge Check Noise
P-30_20-06 JUL 01 Fuel System - Accelerator Pedal Squeaks
P-82_64-138B JUN 01 Cellular Phone - Voice Recognition System Installation
P-54_10-053 MAY 01 Battery - New `Fleece' Battery Technology
S-00_00-072 MAY 01 Emission/VIN Label - Availability
S-58_091A MAY 01 Special Tool - Universal Valve Spring Tool
S-05_010A MAY 01 Tools - Universal Valve Spring Tool
S-58_20-93B APR 01 Fender/Interior/Fascia Cover - Availability
S-58_00-118 MAR 01 Engine Oil - Approved Evacuation Equipment
S-00_40-071 FEB 01 Synthetic Oil Recommendations - For FFS Vehicles
S-40_10-036 FEB 01 Tires - Maintenance & Inspection
S-60_004A DEC 00 Body/Frame - Dedicated Straightening Equipment
S-58_094A DEC 00 Chassis/Frame - Dedicated Frame Straightener
S-60_00-012 DEC 00 Special Tool - M20 Resistance Welder
S-58_30-103A DEC 00 Special Tool - Resistance Spot Welder
S-58_30-115 DEC 00 Special Tool - Resistance Welder
S-60_00-008A DEC 00 Special Tool - Spot Welder
S-40_10-034 DEC 00 Tires - High Performance Tire Storage
P-91_60-46 OCT 00 Rear Door Airbag - Deactivation/Activation
P-40_10-033 SEP 00 Tires/Snow Chains - Factory Approved Specifications
S-82_70-136 AUG 00 Timeport Portable Telephone Programming
P-58_40-113 JUN 00 Tools - Dedicated Frame Straightening Equipment
P-60_10-11 JUN 00 Tools - Frame Straightening Equipment
MB
Here is one for you. It already has all the mods done so you will not have to spend an extra penny:
https://mbworld.org/forums/c-class-w...urbo-w203.html
'05 C230
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Alfa Romeo 164L
2001 C240 Sedan
General Recalls
Service Bulletins
2001 C240 Sedan
General Recalls
Service Bulletins
But this does help a lot with narrowing it down to which car I should get.
Where do you live?
In SoCal there are a lot of great w203s.
For example a 2003 C32 with 81,00 miles for $17,000. But that's not all this C32 comes with extended warranty that ends: 178,000 mile 2018 EXTENDED WARRANTY
That means this car will probably get you through Grad School and maybe even If you decide to go with a PhD![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
What i'm trying to say here is Look for a car that has extended warranty![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Then you won't have to worry about this breaking or that breaking.
Good Luck
To answer your question this is my first Benz as we'll and I recently got it and it has 25K miles. We'll just have to wait and see. So far so good (knock on wood).
Good Luck
02 C320 Sedan
Where do you live?
Good Luck
Good Luck
If i was still working i would trade my car in for that c32 right there =D
02 C320 Sedan
Sucks being 20 with no credit score
03 g35 coupe...........02 c32 Sold
i say get a c32..difference between a c320 and c32 is only $6k. When the difference was more like $20k new.
If not a c32, try to look for 05+ model. Most of the problems have been fixed by then.
2019 E450 Sedan 4Matic
For 8-9k its kinda tough getting a W203 sedan with normal mileage especially if you want the manual. I got my 01 c240 last year for 9500 which was amazing then but now I regret it. Ny newb *** didn't realize that all the parts cost way way more than an equivalent part for say a honda or something. That and the fact that first 2 years of a new generation have more problems. If you have a stable and decent income and you can work on basic-intermediate level stuff on your car, then its fine, otherwise don't bother.
