damn its been so long this happened!
Old May 29, 2009 | 08:30 PM
LinDenKid's Avatar
C230 coupe 2002
ok so it was snowing , i'm driving 20 mph or less , im about to take a turn , and my car slides sideways towards the curb , and i hear a little bumm... i get out the car and look at my left rear rim, and it has a litlle rash, not a bad one, so i headed home!.. two months later(yesterday) , i start hearing a clank , clank.. on my right rear wheel. Brother-in-law says its the hub bearing , what else could it be , i got under the car , nothing wrong.. only the clanking noise, when i lift the car and turn the wheel.. any thoughts would be appreciated (sorry for my grammar/spelling) thanks to anybody that wants to contribute!
Old May 29, 2009 | 08:32 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The title to this thread is confounding.
Is your brother-in-law a mechanic or did he stay at a Holiday Inn Express last night?
From what I can make of this, you need to take it to a wheel/tire shop.
Old May 29, 2009 | 08:58 PM
LinDenKid's Avatar
C230 coupe 2002
he actually knows a bit about cars... i know i should take it to a mechanic , just trying to get second opinions or ideas...
Old May 29, 2009 | 09:04 PM
LILBENZ230's Avatar
I was kidding around with you.. I don't know much about the wheel assemblies.
Old May 29, 2009 | 09:17 PM
Glyn M Ruck's Avatar
Super Moderator
Problem is likely the wheel bearing or outer CV joint.
Attached Thumbnails damn its been so long this happened!-shaft.gif   damn its been so long this happened!-suspension-wheel-bearing.gif
Old May 29, 2009 | 09:35 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Seriously Glyn, how do you get such great images?!
I need that!
Old May 29, 2009 | 09:52 PM
skittles's Avatar
Moped
i think he has WIS.
Old May 29, 2009 | 09:59 PM
linkmustang's Avatar
Where can I buy wis
Old May 29, 2009 | 11:28 PM
mleskovar's Avatar
'17 Jaguar XF
Clank clank isn't a bearing noise. Maybe something came apart in the parking brake assembly? Don't assume that the bump two months ago is the cause of the noise. If you can turn the wheel by hand and hear the noise you should be able to pinpoint it. Can you?
Old May 30, 2009 | 08:28 AM
Super Moderator
I need that!
Tru - I've collected them over the years from MB. I don't have WIS but that is probably the source of the drawings. I would love WIS. Let me know what you want & I will try & find - Do you specifically want rear axle? My filing system sucks but I have a new rule. When I find something to help a member it now goes in a related file. So the more I help the better my filing becomes.
Old May 30, 2009 | 08:32 AM
Super Moderator
I agree with Mleskovar that clank clank is not typical bearing. It could be brake assembly & it certainly could be outer CV joint if the boot has failed & let the grease out & sand in. It can also be diff, but you seem to indicate hub & the diff would make other noises as well.
Old May 30, 2009 | 05:38 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I lost traction once, and went sideways into a curb. (in a FIAT X19)
Both wheel bearings went out within a year.
But that doesn't mean thats your problem.
A wheel bearing tends to be a loud droning noise with the car moving that
changes pitch as the speed changes, FYI.
Old May 30, 2009 | 06:12 PM
Super Moderator
Fiat X 19 had smaller bearings than my vacuum cleaner.
Old May 30, 2009 | 06:41 PM
W203E35's Avatar
2006 C350 Sport 6MT
Originally Posted by linkmustang
Where can I buy wis
http://cgi.ebay.com/ebaymotors/Merce...sQ5fLiterature
Old May 30, 2009 | 06:59 PM
Super Moderator
Hmm - not Vista compatible!
Old May 30, 2009 | 07:14 PM
advans's Avatar
C55 ///AMG, 535xi
I had to replace my wheel bearing on my rear pass wheel on the C55, because I cracked a wheel
its possible that its the wheel bearings
Old May 31, 2009 | 01:42 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
I think compatibility's the least of your computer worries if you have Vista!
Old May 31, 2009 | 09:44 AM
Super Moderator
Yeah! - I know what you mean. I've got Vista Business settled now after many service packs.
Old May 31, 2009 | 12:46 PM
LinDenKid's Avatar
C230 coupe 2002
Thanks guys , i was going to take everthing apart , but i decided to take it to a mechanic and enjoy my weekend lol, i remember snapping three tools, trying to get my honda accord axle out(replacing the clutch on it) . Gyn m Ruck... very nice images.. Thanks guys!!!
Old May 31, 2009 | 12:48 PM
LinDenKid's Avatar
C230 coupe 2002
that's exactly how it sounds, you know my english sucks , its hard for my to explain . The faster i go the noise changes.
Old May 31, 2009 | 12:59 PM
Super Moderator
Sounds like a Conti Sport Contact 2 or 3 tyre
Old May 31, 2009 | 08:48 PM
W203E35's Avatar
2006 C350 Sport 6MT
If you guys really need this software and have Vista you can run a virtual XP.
http://www.microsoft.com/downloads/d...2-2dc0b40a73b6
Download Virtual PC 2007 (free) and all you need is a copy of XP. Install it and enter the product key. You will have to activate it but thats not a problem because you have 30 days so you can use it 30 days till you have to install it over again.
Or you can purchase an OEM version of XP for 100 bucks (full not upgrade) and do a dual boot. (Have Vista and XP on one machine).
Or you can do what I usually do is get a copy from a "Friend" and during activation call Microsoft and say "You are reinstalling windows because your hard drive crashed" "Windows copy has ONLY been installed on this exact same machine on NO other machine" "NO hardware has ever been changed on this machine" and they will give you the validation code.
I personally would go with the dual boot.
Once you do a dual boot it is wise to use an imagine software and image your hard drive. The best one out there is Acronis True Image then Ghost.
Vista is horrible made a lot of PC users switch to MAC.
Old May 31, 2009 | 09:03 PM
bdgdl08's Avatar
You know, I love my mac... I've never had any issues other than compatibility issues. Because of this, I run Windows on a partition of my hard drive. I can boot in either Mac or Windows... and in Mac I can run the Windows partition as a virtual machine. And the best part... I have XP!
Old May 31, 2009 | 09:11 PM
W203E35's Avatar
2006 C350 Sport 6MT
You have the perfect combo. All you really need is MAC and XP
Old May 31, 2009 | 09:45 PM
bdgdl08's Avatar
It's great. The problem I had was that I bought my computer after XP was no longer available in stores. The program I used to run Windows as a virtual machine is great because it will copy XP from your old computer, or even copy your hard drive with all your files and all.
