C-Class GAS/FUEL Filler CAP (issues & problems) Thread
Old Jun 7, 2009 | 09:45 PM
  #101
see240wag's Avatar
2012 GLK 350
Thumbs down 2004 C240 Gas Cap retaining cord broke
What is required to fix the rubber cord that holds the gas cap to the body while off. It broke probably from the heat down here and just age.
Old Jun 7, 2009 | 10:01 PM
  #102
Alba's Avatar
2004 CLK 320 Convertible
Mine broke on my 2002 C230 as well. Bump!
Old Jun 7, 2009 | 11:29 PM
  #103
mleskovar's Avatar
'17 Jaguar XF
What did the dealer's parts man say? My guess is the whole cap assembly.
Old Jun 7, 2009 | 11:58 PM
  #104
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The real question is why did you start so many new threads all at once about your car? Another thought is that you cut the retaining cord off completely as it's completely useless.. at least it is to me. I never let the cap just dangle by the cord with the metal pieces banging against the body of the car. You should have a place to snap the cap when removed to avoid it touching the paint.
Old Jun 8, 2009 | 12:31 AM
  #105
IntoTheBlue's Avatar
2005 C230 Sport
I'll be honest, that chord is more than useless. I had a 2004 with a cut gas cap cord, and now have a 2005, and now everytime i fill up my gas i think about how useless that cord is. I'm forced to put the gas cap into that holder, and no matter what gas station i go to, the nozzle pushes against the gascap holder and i feel like its gonna snap the filler door off if i don't hold the nozzle.
When the cord was cut i was able to just lay the gas cap inbetween the trunk lid and rear glass and give any finicky nozzles plenty of room. Any one who complains about a cut gas cap cord and is afraid of losing it should be restricted to driving Power Wheels and not real cars.
Old Jun 8, 2009 | 06:11 AM
  #106
Glyn M Ruck's Avatar
Super Moderator
That strap is a pain. Only good thing in a full service country is that it prevents the pump attendant from walking off with your fuel cap. I stand & hold the darn cap while they fill my car so it doesn't scratch the bodywork or the cap in that stupid door mounted holder.
Old Jun 8, 2009 | 08:52 AM
  #107
see240wag's Avatar
2012 GLK 350
You all have the wrong idea about me. This vehicle is like new, in and out. I never let the fuel cap hang on the string. I just wanted to know whether there is a trick to replacing it without having to pay for a new gas cap. I've replaced headlights in this car as well as batteries for the key fobs, saving $$ in the process.
Old Jun 8, 2009 | 03:52 PM
  #108
LILBENZ230's Avatar
Just cut it off and be done with it. Otherwise I can't see how you won't be buying a new cap.
Old Jun 8, 2009 | 06:14 PM
  #109
Super Moderator
In some parts of the world it is available as a spare & would be an easy DIY - Hopefully you can buy one in the US
Old Apr 3, 2011 | 01:14 PM
  #110
sig05's Avatar
2003 C320
filler cap issues 2003 c320
Anyone had the issue of the "check filler cap" message complete with blinking light....usually happens around the time i hit a half a tank but not always, i have tightened the cap.. that didnt work so i replaced the cap...didnt work.. is there something else this could be?? and what can i do to resolce the issue? thanks for the help
Old Nov 23, 2011 | 02:23 PM
  #111
cosmo88_7's Avatar
2004 c230 kompressor
It really worked for me!!! Thank You for your help. I've never had this happen before.
Old Nov 23, 2011 | 03:20 PM
  #112
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
theirs a fuse for the filler neck i think
Old Apr 28, 2014 | 06:27 PM
  #113
cadbob's Avatar
2003 SL500, 2016 F250, 2017 Jeep Renegade
I understand the Cord Issue but would like it on myself or at least try it out the correct way. How do you remove the Filler Cap Clip the holds the strap to the Fuel Door? I tried prying it but I'm afraid of breaking the Cap Holder on door. The Center Pin is Flush on Rivet so needle nose pliers wont work to pull pin.
