Clunk from front-end with C32 sway bar
C240 - 6 speed
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
About two weeks after the C32 bars were installed, I have a clunk noise coming from the front end of my C240.
I am presuming that something got loose progressively in two weeks time.
It is easy to reproduce. Open hood, lean on left front shock tower and push in, and "clunk-clunk".
Any comments?
Any comments?
Re: Clunk from front-end with C32 sway bar
Originally posted by bora
About two weeks after the C32 bars were installed, I have a clunk noise coming from the front end of my C240.......It is easy to reproduce. Open hood, lean on left front shock tower and push in, and "clunk-clunk".
Any comments?
Any comments?
I had a similar clunk, and it was that we hadn't tightened the bolts enough. Now tighter, now no clunking.
Since that's the most recent thing, I'd start there before checking on others.
2002 C240 Classic
i know when i get out of my car i hear a clunk everytime. others have said that its the e-brake engagement "feature". not sure if this is what you're looking for, but possibly a suggestion. from what i hear, its normal.
i lifted the car and checked all the bolts and they're as tight as they can get.
but, i will continue monitoring all the bolts for a while just to make sure.
the "open hood/press down/listen for clunk" test is much safer than lifting the car - thanks for letting me know.
C240 - 6 speed
Originally posted by KWiK
You need to tighten the bolt attaching the sway bar to the end link
He told me that the rattle should not come back, but from my prior experience I know that if the hole is much larger than the bolt, the bolt will work loose again.
We shall see.
I am thinking about welding a steel washer of the correct size to the mounting bracket to ensure that the fitment is correct, any more ideas?
C240 - 6 speed
I'm not clear on where the hole was drilled. Was it the end of the sway bar or the end-link mounting hole in the strut?
C240 - 6 speed
Originally posted by steve s
that would be where one of the stress points the sway bar puts down...
Can you please expand on this?
Bora
You are right, that was what it was, however one thing the mechanic told me has worried me. Apparently they had to drill a larger hole in the sway bar mounting bracket to accommodate the C32 end-links during the install and it looks like they over-drilled one of the holes (at least).
We shall see.
We shall see.
C240 - 6 speed
Originally posted by TNblkc230wz
There should be a rubber bushing on both sides of the hole. As long as the bushings can't pull through, it should be ok
While I get the race car prepared for my next race this weekend, I am going to pull the wheels off and take a look myself.
I should have done the job myself, just got lazy.
Worse comes to worse I may use double nuts to prevent the nuts from loosening with the vibration together with Loctite. The car is very quiet when the end links are tightened down nicely.
1 Post
2002 C230 Coupe
When I installed the front sways there was only a hole on each end of the sway bar...
2002 C230 : 2007 C230
Originally posted by 20FHK02
Excuse me: where is the end-link mounting hole in the strut??
1996 C36 AMG, 1995 Volvo 850 Turbowagon
Hi Steve
Bora
Hi Steve
Bora
here's something that may be interesting to u...previous q about anti-sway bars
C240 - 6 speed
the sway bar connects on side of the suspension to the other usually with some sway bar endl links. on a macpherson strut (in the volvo at least), the link is a tiny little bar that connects the strut housing to the bar. not sure about the new w203 macpherson strut. there should be something that holds the bar in place on either the suspension subframe or the chassis itself. but anyway...say when ur left suspension compresses on a right hand turn...this pushes down on the sway bar...at the connection...the bar is twisted, and acts on the extended right suspension, keeping that extended motion in check. these forces are applied at where the sways and the struts and the end links are connected...needless to say, if one of these items becomes loose, the benefits of the anti-sway bar are not totally realized...that's what i meant...hope that was useful...
I was fully aware of this, but it is a good description. I am now wishing that I had stayed with the much thinner C240 end-links vs the C32 AMG end-links which are thicker and beefier. The reason why I wanted to change is that eventually the stronger swaybar will break the weaker end-links. Of course I was not expecting the dealership mechanic to over-drill the hole.
Oh well, I will dig in and take a look at it this weekend.
C240 - 6 speed
If all you changed was the front sway, then that's the only end-link you should have touched, but the other end of that end-link is attached to the strut
2002 C230 K
I think using the much thinner end-link from the non-C32 cars is asking for trouble. It will eventually snap due to the thicker sway bar.
203-323-21-89 - Rod - $47.18 (2)
I assume that these are the linkages from the swaybar to the rest of the suspension. Do you guys think that this part you think should be changed as well? Also some people mention that things need to be drilled and others have done it with no drilling. Is it the end-link/rod connection to the strut where drilling is necessary?
- BT
PS: Does anyone know the torque values for all of these connections (to prevent putting the things on too loose)?
C240 - 6 speed
Originally posted by trench
In the initial AMG sway bar/swap post there was mention of this part (which later people said wasn't necessary to change):
- BT
- BT
I would upgrade the end-links with the sway bars. My car was an early 2001 model (10/2000 build date) so I am thinking the later cars may not have this problem. If you drill it, make sure you come at a straight angle which may require removal of the wheel and possibly the rotor. If you have a right angle drill that should come in handy.
As I said, I think this is an easy job, I just got lazy and asked the dealer to do it, big mistake.
At least I now have a reason to upgrade the H&R coilovers.
2002 C230 K
Now, by problem, do you mean the need to drill? Also, I'm not exactly clear what needs drilling. Please refer to the crappy diagram below: is it the the #1 hole that needed drilling out (and in the end-link or on the strut)? Or something completely different?
Thanks, BT
PS: If you don't mind me asking, which Bay Area dealer did you have this done at?
C240 - 6 speed
OK, I'm sold on the rod/end-link.
Now, by problem, do you mean the need to drill? I'm also not clear exactly what needs drilling. Please refer to the crappy diagram below. Was it the the #1 hole that needed drilling out (and in the end-link or on the strut)? Or something completely different?
Thanks, BT
Thanks, BT
accommodate the AMG end links and hence the problem.
If you are careful enough, you should not have any problems.
