LILBENZ230's 2005 C230K SS Adventures Thread
The wipers DO wipe over the rain sensor. This is absolutely necessary. If your blades don't wipe over the rain sensor area then you will wind up with the wipers at full speed for any rain.
The reason for this is because the system determines how often to wipe the windshield based on how long before water builds back up between wipes.
If the area above the rain sensor is dirty or smudged you will also have the problem described because the system thinks it's still wet even after it just wiped. If the outside of the windshield is fogging up for any reason (as sometimes happens) the wipers will also work faster than they should, same reason.
I use a chemical windshield cleaner to strip the glass every so often (maybe twice a year) and then I rain-x the entire windshield including the area over the sensor.
Unless the outside of the windshield fogs up my rain sensor works perfectly all the time - it's always set to auto. It definitely does not run the wipers too fast. If anything, it waits until there is a good amount of water collected on the glass before triggering a wipe. I suggest you clean and polish the area of the glass around the rain sensor, then apply some rain-x. Works for me. I think proper application of the rain-x over the sensor area will slow down the wipers if anything because the water beads, taking up less surface area on the windshield. That should fool the sensor into thinking there is less water accumulated on the glass. When your car had a brand new windshield (the conditions the rain sensor was designed to work perfectly under) the water probably beaded up the same way it does after an application of rain-x.
LILBENZ - get longer blades
I cleaned the windshield and cleaned the wipers but they smear water around and the sensor keeps speeding them up. I think that the smearing the wipers are doing is making the sensor think that there is more water than there really is.
So I guess this answers the question I originally posed! If your wipers are smearing water over the rain sensor rather than clearing it, it will cause them to run too fast. That's my problem and it should be fixed with new wipers that actually do their job. I'll report back!
Thanks everyone for your input, especially thanks to you, Glyn, for your documents that confirmed the theory I had.
Most manufacturers and glass companies suggest a product made from egg shells called Bon-Ami. It is a white powder for cleaning kitchen and bath surfaces. It is a mild abrasive, but will not scratch glass. Sprinkle on wet glass and use a clean sponge to work it into a slurry to clean the glass fully. Oh, resist the urge to use Dawn dish soap, unless you car was painted by Wedgwood, Lenox, or Mikasa.
If you want to use Rain-X, keep in mind it is an emulsion product. After application, the liquid must dry to a haze, then be completely removed by buffing. It forms a smooth layer over the comparatively rougher surface of the glass. This allows the water to slip right off.
Heed Moviela's comment - good local knowledge - Coke is not Coke the world over. The variation in taste from market to market is enough to tell you that. Man I've drunk a lot of Coke in my global job trying to stay away from defiled water & Delhi belly.
Last edited by Glyn M Ruck; Mar 2, 2009 at 03:37 PM. Reason: Feeling a little high - pink elephants - Oh crap!
The dealer I bought it from did the brake job as a condition of purchase since they were worn out already. Is it possible they could have installed them incorrectly or used the wrong size pad? No errors in the dash and no funny noises or vibrations are present. Just both front rotors have that different colored ring around them outside of the surface.
Glyn you're such a huge asset on here. Thanks for all the times you've already helped me.
I don't think you have anything to worry about.
Can anyone confirm that Mercedes service records are subject to HIPPA the same as a person's medical records?
Asked my SA for a VMI as part of a PPI that was, not coincidentally, conducted elsewhere.
He said “no problem” and invited me back for service and warranty work. It lists the former owner’s last name which, of course, I already knew. He has received a bottle of a quality California wine at Christmas every year hence and taken care of several goodwill (expired) warranty repairs. Sometimes, it’s who you know and how you ask.
Medical or credit records and a vehicle’s service/warranty history should hardly be afforded the same level of privacy, IMHO.
Of course, she went off on her own, and bought something else.
(and now bi*tches it doesn't have the options she wanted..)
HIIPA is federal law, and doesn't include personal transpo, FYI.
