Where to buy Mercedes Oil Filter Wrench?
Subscribe
Jun 10, 2009 | 11:23 AM
It appears from my searching this forum that I need a 74mm 14 flute wrench to change my oil filter. My question is, can I find this at an auto parts store (I have been to 1 with no luck), can I buy one from the dealer, or do I need to order one somewhere online?
Thanks for any help!
- Bill -
Reply 0
Jun 10, 2009 | 11:26 AM
You can buy them at the dealer.
103-589-02-09-00
Reply 0
Jun 10, 2009 | 11:28 AM
can this tool be used on W209s or other Merc models?
Reply 0
Jun 10, 2009 | 11:48 AM
yeap
Reply 0
Jun 10, 2009 | 01:09 PM
i bought mine at autozone $11
Reply 0
Jun 10, 2009 | 01:20 PM
Quote: i bought mine at autozone $11
What's it called, you have the part number? There's an autozone a block away from my work, I might swing by and pick one up just in case
Reply 0
Jun 10, 2009 | 01:23 PM
Quote: What's it called, you have the part number? There's an autozone a block away from my work, I might swing by and pick one up just in case
no, what i did was looked at the cap and went inside and looked for the closest one(had to go and change it 3 times but it worked) 74mm should be about right
Reply 0
Jun 10, 2009 | 01:32 PM
I'm fairly certain it's called 74/76mm with 14 flutes. That's how mine is labelled.
I'm going to warn against the plastic ones...they often slip. I've got a metal one that has a fitting for a 3/8" drive so you can properly set torque (25N*m). This cap fits many "foreign" cars.
Reply 0
Explore
Jun 10, 2009 | 01:35 PM
Quote: I'm fairly certain it's called 74/76mm with 14 flutes. That's how mine is labelled.
mine's is also metal...
Reply 0
Jun 10, 2009 | 01:37 PM
Here's a fancy one for $20:
http://www.samstagsales.com/mercedes.htm#oil
HZ 2169
Reply 0
Jun 10, 2009 | 01:40 PM
Here's another at Assenmacher:
http://www.asttool.com/detail_page.p...nge%20Products
Reply 0
Jun 10, 2009 | 01:42 PM
and another:
Reply 0
Jun 10, 2009 | 01:43 PM
and the elusive 32mm wrench:
Reply 0
Jun 10, 2009 | 02:08 PM
The one I have is also from Autozone.
Reply 0
Mar 6, 2010 | 08:50 PM
What is the type of the wrench?
I go to Autozone too. But there has NO number such as 74/76 mm on the wrench. There have Type A, B, C, etc. Which type it is 74/76 mm wrench?
Thanks.
Reply 0
Jul 23, 2010 | 11:35 PM
It'll be a Type B and it will be 76 mm and...
...it will be slightly loose.
Many say it does not matter, but that slack means the pressure is on the edges, only, of the filter housing and it means that the wrench will jam onto the housing.
Been there. Done that.
I'd get the real 74 mm wrench. They are sold on eBay for $16 on up, delivered.
Or...I'll sell you my Type B, cheap!
- nopcbs
Quote: I go to Autozone too. But there has NO number such as 74/76 mm on the wrench. There have Type A, B, C, etc. Which type it is 74/76 mm wrench?
Thanks.
Reply 0
Jul 24, 2010 | 12:25 AM
I have been using a rubber strap type wrench. One that you pull the thick strap to tighten it and turns the handle. It works very well. You don't really need the special filter wrench.
Reply 0
Jul 24, 2010 | 06:46 AM
Hmmm.
I'm sure that will work to take the thing off, but how do you torque the housing back on to the 18.5 ft-lb tells you to?
My guess is that you don't torque it.
- nopcbs
Quote: I have been using a rubber strap type wrench. One that you pull the thick strap to tighten it and turns the handle. It works very well. You don't really need the special filter wrench.
Reply 0
Subscribe
Currently Active Users (1)
