c180 sonny's C180 Kompressor Thread
Old Jun 16, 2009 | 02:20 PM
c180 sonny's Avatar
C180 Kompressor Saloon
Red face chopped springs?
hiya
has anyone chopped their spring.
what are the pros and cons and is it safe?
thanks
Old Jun 16, 2009 | 02:58 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Did you possibly do a search?
There is a ton of information available for almost any question asked before on these forums.
Old Jun 16, 2009 | 03:41 PM
M-bENZ's Avatar
Corrolla
Originally Posted by c180 sonny
hiya
thanks
What do you have ? C230 ? or ?? show us some pics...I think one my friend trying to sell his.
Andy
Old Jun 16, 2009 | 06:23 PM
c180 sonny's Avatar
i have a c180 komp
i have put the CLS wheels on and the car is in the bodyshop now and it having the AMG kit going on. ill post pics up soon.
Old Jun 16, 2009 | 09:05 PM
M-bENZ's Avatar
Corrolla
please tell me u not in europe ? lolz
Andy
Old Jun 16, 2009 | 09:15 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
If you are on the mood to experiment with cutting, I can offer you an OEM set from my (sold) '2002 C230 Coupe to play with. PM me if interested.
Old Jun 17, 2009 | 05:49 AM
c180 sonny's Avatar
yes i am in the UK,
is this a problem????
Old Jun 17, 2009 | 05:52 AM
HellsAngel's Avatar
03 c320 coupe
yes i am in the UK,
yes it is for shipping items as big as springs..
Old Jun 17, 2009 | 08:55 AM
linkmustang's Avatar
I have done this on my 92 mustang easy to do I cut two coil off
Old Jun 17, 2009 | 10:06 AM
HellsAngel's Avatar
03 c320 coupe
the springs compression ratio wont stay the same.. you are compromising ride quality.
Old Jun 17, 2009 | 12:31 PM
c180 sonny's Avatar
chopped springs, lowerings springs and coilovers, all these will compromise the ride quality. no matter what you do
Old Jun 17, 2009 | 12:41 PM
hieracity's Avatar
C230 K Coupe (05)
if u chop ur spring, ur stock shocks will die out a lot earlier.
correct me if im wrong ppl...
Old Jun 17, 2009 | 01:23 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
This is not necessarily true, but it can be true in some situations.
Some shocks/struts have a certain ride height that they are designed for, some don't. Even with the one's that dont, it will still be slightly harder for the shock/strut to dampen the stiffer (higher spring rate) spring and it may therefore get hotter with repeated cycles.
If you only cut off a coil or a half of a coil and raise the spring rate <10%, you should be fine, provided the shocks are not designed for a specific ride height.
I have no idea how the dampers on a C class are designed, but if the aftermarket drop springs do not require you to change your shocks and struts, then I would advise that damper wear for a setup with mildly trimmed springs will not be noticibly worse than the wear rates for a setup with aftermarket springs.
Old Jun 17, 2009 | 01:36 PM
c180 sonny's Avatar
Smile c180 sonny's C180 Kompressor Thread
hiya
here are some pics of my car. this is all i have cos its in the bodyshop at the moment
im getting the AMG bodykit on it and i wana lower it but dunno how. chopped springs or lowered springs or coilovers.
could someone to a little photoshop for me so i can see what it looks like. please
also i have alpine 6.5" components in the fron, directed shallow fit 6.5" 2 ways in the rear doors and 2 x 12" subs in the boot/trunk and everything is amped up and running off the original head unit.
8k HID conversion
and thats about it for the time being.
what do you think?
comments good or bad please
Old Jun 17, 2009 | 02:37 PM
M-bENZ's Avatar
Corrolla
You are correct.
Old Jun 17, 2009 | 02:38 PM
M-bENZ's Avatar
Corrolla
It is a problem.
Andy
Old Jun 17, 2009 | 03:19 PM
W203E35's Avatar
2006 C350 Sport 6MT
Looks good,
I wouldnt chop the springs. I would get coilovers but they are expensive.
Have you thought about putting another kit?
Brabus, Lorinser, Reiger, WALD?
Old Jun 17, 2009 | 03:40 PM
W203E35's Avatar
2006 C350 Sport 6MT
Spend the money and get Springs around 60.00 US Dollars
Or you can get Coilovers for 1200.00 US Dollars
Your spending time and money into the AMG kit why not pay a little more and get good springs or coils as well.
Old Jun 17, 2009 | 04:04 PM
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
I agree, don't chop just lower with good spring kit. Like your rims. Nice car.
Old Jun 17, 2009 | 04:18 PM
W203E35's Avatar
2006 C350 Sport 6MT
Never mind the other kits, I saw you went with AMG. Keep it Original
Here is the link to the best coils for your car (in my opinion)
http://swerve.rpmware.com/kw_suspens...2/i-68519.aspx
Old Jun 17, 2009 | 04:48 PM
c180 sonny's Avatar
thanks for the comments
i have just checked that site and my car isnt listed. mines a c180 komp
Old Jun 17, 2009 | 05:02 PM
c180 sonny's Avatar
what about doing this for a temporary fixe then lower it properly within a month.
is this a good idea?
Old Jun 17, 2009 | 05:25 PM
W203E35's Avatar
2006 C350 Sport 6MT
Sure if you are going to do it yourself?
If you are going to have to pay someone to take off the springs, cut them, put them back on and then you get coilovers or springs in a month it wouldnt be worth the money unless someone can do is for free.
You might as well drive it like (stock -unchopped) that for a month then get it done properly (springs or coils)
Up to you but if its not free then you are wasting money.
Good luck
Old Jun 17, 2009 | 05:29 PM
W203E35's Avatar
2006 C350 Sport 6MT
It shouldnt matter, I would go with the year and make sure you dont get 4 matic.
You can try contacting them. I'm pretty sure there is no differnce.
Can anyone chime in?
Old Jun 17, 2009 | 05:44 PM
c180 sonny's Avatar
its going to be free.
i just have to save up more money and get proper suspension
thanks guys
