TRANSMISSION SERVICE COST
Old May 16, 2010 | 10:08 AM
  #51
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Originally Posted by viku_st
to johnand,
helpful info posted by you. thanks, but I'm wondering when your 7G is due for service? waiting for DIY,
Just bought the fluid, filter, gasket, bolts, and standoff pipe. My service is due sometime next month. I now have a STAR system, so I will show how to use that to check level as well. I will probably video tape it as well. Stay tuned.
Old May 16, 2010 | 11:58 AM
  #52
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
John - if your service is due next month, does this mean you'll be at 74,000? You're catching me up! Drats! (81,115 here).
Old May 16, 2010 | 12:37 PM
  #53
johnand's Avatar
Super Moderator
Close, I'll be at 72K. I am at just under 70K now. I did the 1st service at 36K, and am going to do the service every 36K, as is the recommended ROW service interval that Glyn mentioned to me. 60KM is the recommended, which is just over 36K miles.
1st part of next month, I will take a 1K mile trip.
Old May 16, 2010 | 01:15 PM
  #54
viku_st's Avatar
07 E63
Where did you get the STAR? ones I was looking for but in turn out to be a bit expansive , $7500 I guess was for used one, and the prices were going to 15000 and more. probably ones from china some where around $1000 .
Any way, waiting, how much fluid did you buy, and will you follow the process described earlier on this tread?
Old May 16, 2010 | 01:31 PM
  #55
johnand's Avatar
Super Moderator
I bought one of the Chinese clone multiplexer and cables from Ebay for $550, and installed the software using the install guides from JCRecordings.com A real full blown STAR system from MB will set you back $25K. Obviously out of the question for a shadetree mechanic. The clone system does what I need to for a fraction of the price. If I owned a shop or made a living from the system, I would buck up and buy the real thing.
Bought 2ea 4L bottles of ATF here: http://www.rmeuropean.com/Part-Numbe..._F84D7082.aspx
Yes, I will follow the process I described earlier which is possible w/o a STAR system. I will also add the fluid check procedure for people that have access to STAR.
Old May 16, 2010 | 02:11 PM
  #56
viku_st's Avatar
07 E63
I was looking for a 722.6(for may C230) and found this DIY https://mbworld.org/forums/w211-amg/...ion-flush.html, , just thought may be interesting, and that he used 10L of oil.
Old May 16, 2010 | 02:25 PM
  #57
johnand's Avatar
Super Moderator
Yes, I have seen that. A flush was a great idea in his case, because the fluid looked like crap. In my case since I did the 1st service at 36K, and going to continue every 36K, a flush is not necessary IMO. Flushes are usually done when people let regular transmission service go to long. A flush can be done the same way on the 7G, but would be even more of a PITA since there is no fill tube and has to be filled from pan drain plug. You also waste a LOT of fluid doing a flush.
Old May 16, 2010 | 03:06 PM
  #58
viku_st's Avatar
07 E63
That what I am considering to do, last transmissions service the dealer could find was done at 39K so I will do a complete flush, because I have 106K now. TITAN meet the spec but I was going with Genuine mercedes do you think it's a big difference? where titan is made?
Old May 16, 2010 | 06:16 PM
  #59
hieracity's Avatar
C230 K Coupe (05)
Wow, i just got my transmission fluid and filter changed, Around 52k. Car drives a LOT smoother. And I paid only $120.... (genuine MB fluid too)
Old May 16, 2010 | 06:20 PM
  #60
viku_st's Avatar
07 E63
Do you have a 722.6 or 722.9? probably 722.6 with 5 as on my 02 C230K, which DIY you followed?
Old May 16, 2010 | 06:46 PM
  #61
hieracity's Avatar
C230 K Coupe (05)
I have no clue what those numbers mean buddy . lol So what do those numbers mean?
I took it to a mechanic that I trust and have been going to for all my car maintenance.
Old May 16, 2010 | 06:50 PM
  #62
contact148's Avatar
2003 c240 4matic wagon
just had a transmission fluid and filter change done at MB here in canada cost me $260.00 tax in 118,000km 1st time it was ever done 2003 c240 4 matic wagon
way easier then doing it myself!!
they dropped the pan changed the filter and changed 4 liters of ATF so about 1/2 of the fluid
Old May 16, 2010 | 07:49 PM
  #63
LILBENZ230's Avatar
It's never been done on my C230K at 81,150 miles. It's on my have-done list (not my to-do since I am not mechanically inclined).
Old May 16, 2010 | 08:57 PM
  #64
nrg_mike's Avatar
2005 C320 Sport, 2010 C300 Sport
The transmission service is worth every penny. It's a shame how many people neglect it for so long.
Old May 17, 2010 | 02:37 AM
  #65
W203E35's Avatar
2006 C350 Sport 6MT
I need to do this ASAP. I'm at 43k still with same fluid. John didn't you have a DIY somewhere? You changed your buddy's tranny fluid huh?
For some weird reason when I say tranny it reminds me of Mike
Old May 17, 2010 | 10:07 AM
  #66
johnand's Avatar
Super Moderator
The Fuchs Titan 4134 ATF IS the OEM fluid, so no sense paying more for the bottled labeled for MB. Plus the 4L jugs are more economical.
Old May 17, 2010 | 10:11 AM
  #67
johnand's Avatar
Super Moderator
Yep, in this thread: https://mbworld.org/forums/3668015-post34.html That is a general DIY. I will have a full blown DIY posted next month. Yes, I change my buddy's fluid in his 2007 W203.
Old May 17, 2010 | 10:16 AM
  #68
nrg_mike's Avatar
He's just jealous coz my milkshake brings all the boys to the yard...
Old May 17, 2010 | 10:19 AM
  #69
johnand's Avatar
Super Moderator
I haven't quite figured out if you are lucky or not, that Karo has moved his attention and jokes to you from Patrick
Old May 17, 2010 | 01:03 PM
  #70
Shadowsnake's Avatar
C230 Sport
Does this oil can be used on the 722.6(5-speed) tranny? I think I read that it works...
I could get it, 12qt. for $185 shipped from rmeuropean, the 722.6 spec(mercedes) its around $235.
And my stealership want $25/qt.... + tax $320
Mine's @74k, this week i'm going to buy the oil for a completely flush.
Old May 17, 2010 | 01:31 PM
  #71
johnand's Avatar
Super Moderator
Absolutely, the new spec 236.14 is backward compatible to the 722.6 5-speed transmission.
Old May 17, 2010 | 01:45 PM
  #72
skittles's Avatar
Moped
Penske West Covina. 249.99 + Tax + Discount Coupon!
Old May 17, 2010 | 07:01 PM
  #73
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I did the full flush at 120K.
My tranny was clunking and shifting like crap.
New Fluid and filter fixed up like new.
I'm at 153K now, and the problem has not returned.
I'm going to flush it again sometime soon....like within the next 10K miles.
just for good measure.
On this forum, it seems the experience from those who have done the full flush is generally a good one, resolves problems.
If it blew up after flushing, likely it was because the correct materials must be used,
and our tranny's have very special fluid specific to Mercedes 5 & 7 speed trannies.
Be sure to replace the orings, order one of these...
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
Originally Posted by phoenix_iii
That's interesting. I've had a number of people post that doing a complete flush and fill ruined a trans (not on this forum). If there is a lot of grit/etc in the fluid, and it is replaced with new clean fluid, that too much friction material is now gone and the trans dies shortly afterwards.
I would like to think that a full flush is always good, but after have both techs and people post the above, I'm not too certain either way. I would imagine just do it at the right interval and it's not a problem.
Old May 17, 2010 | 08:28 PM
  #74
C230 Sport
Ordered 3 4L jugs of fucsh 4134 from rm, i'm doing the full flush on the weekend...
Old May 17, 2010 | 11:22 PM
  #75
FraKctured's Avatar
W203-4M W163
Originally Posted by Glyn M Ruck
As an oil industry man I can assure you that you can never change auto fluids too often. New fluid will never cause the multi wet plate clutches to slip in a box that is in good condition - it will prolong their life. The fluids all have friction modifiers in them to allow a controlled amount of slip before lock up. This additive becomes depleted over time. Change Benz auto boxes at max 60,000 miles. In many torrid markets they recommend every 60,000 Kms. If you know you drive hard or tow with the vehicle then halve that drain interval.
+1
Ruck is Right
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
