TRANSMISSION SERVICE COST
Thanks for the link John and the DIY. When you coming to SoCal?
I did have my 7G serviced at the dealer at ~36K on my car, but did help my buddy change the fluid in his 7G. You need the following tools: http://www.asttool.com/detail_page.p...&manf=Mercedes and a high quality infrared thermometer like: http://us.fluke.com/usen/Products/Fluke+62.htm The Assenmacher 722.9 adapter is $38 direct, and the Fluke 62 can be had for around ~$85. The Fluke has many other uses as well, so it is a good tool to have.
In a few months when my 7G transmission is due for another service I will do a FULL write-up on how to properly service it. Here is a quick rundown, but is NOT intended to be used a how-to guide. Either get the service manual, or wait until I do the write-up. The car must be level!!! 1st, the "drain plug" is also the fill plug. When you take out the drain plug, little to no fluid will come out. You have to use a drift punch to knock the standoff pipe into the pan. Then the fluid will start to drain. Then drop the pan, change the filter, install a new standpipe, and new gasket. Then rebolt the pan on with NEW OEM bolts. The bolts are aluminum and 1 time use. The transmission housing is magnesium. Again, YOU MUST REPLACE ALL THE PAN BOLTS. Then you thread the Assenmacher tool into the pan. Pump fluid into the transmission until it is overflowing. Unscrew the tool. Start the car, run the shifter through all the gear position. With the car running in Park, take the thermometer and read the temperature of the fluid that is now overflowing the standpipe, and out the transmission pan drain plug. Once that fluid is at 40C, stop the engine and immediately put the drain plug in. That is the proper level. As you can see this is different that the typical change, but not really difficult, you just absolutely have to do it correctly.
As far as how often to service the 7G? NA MB service interval in 38K miles, then no other services listed in the service guide. But in the rest of the world, as Glyn pointed out earlier in this thread, MB recommends 7G service ever 60K miles, which is ~37K miles. So, if you intend to keep your 7G running as long as possible, I would stick to that interval.
I had to come over to the W203 forum to find some DIYer's. You'll get flamed in some forums for mentioning that you can change your own fluid/filter in a 7G tranny.
Thanks for the link to the adaptor tool and I'm looking forward to your complete writeup.
I got sidetracked last weekend, but plan on doing the transmission service this weekend.
The flamers seem to be insecure know-it-all snobs who revel in you knowing they have enough money to drive a Mercedes but don't know how to check the air pressure in their tires.
Anyway, I think I can make one of those ATF adaptors shown at the AST site. Did you use one of their pumps with the adaptor?
But, I will continue to try and service my cars myself, until the tools required get too expensive. The $600 I have into my STAR clone system is almost my threshold.
You could easily make one of the adapters, it is just a hunk of steel with 12mm x 1.5mm threads and a hole through the middle. I almost made one myself, but for less than $40, it wasn't worth my time. The Assenmacher tool is of very high quality. I didn't buy their overpriced pump though. Just attached a simple automotive bottle pump hose to the tool. Works great, and is inexpensive.
If I could find the Assenmacher tool locally I would probably grab one. I thought I'd just drill a hole with the lathe on a 12x1.5 bolt and attach a hose like you've done.
I am VERY particular about everything I own, and one of the biggest reasons I work on my own car is I can never get things done how I want by someone else. Same goes for my house. That is why if I am not working on the car, I am working on the house
Yeah, drilling a hole in a bolt would work too, and is super cheap. I bought mine online here: http://www.toolsource.com/mercedes-7...-p-105640.html
Frankly though, it is better to not have a dipstick/fill tube, as they are a large source of contamination. By having the fill through the drain plug, that essentially "seals" the transmission.
The fill tube on my C55 transmission has an o-ring seal which means there has to be a vent somewhere else in the transmission housing. I'd look for it on my STAR service manual if I could ever figure out how to get it to work on 64-bit machine.
Or should I just leave it.... The dealer told me to not service it since it is a lifetime sealed transmission.
I am confused :S
I am confused :S
changed 4 L of ATF, gasket and filter, all parts from Dealer
costed 180$ CDN with taxes
lmao. Was looking at smilies to reply w/ and then I saw this. LOL
