ESP/BAS warning after towing
So I had to have my car towed yesterday due to faulty lug bolts (long story....). One of the front wheels weren't drivable so they needed to tow having the rear tires on the ground.
Since the car was rear wheel drive, the tow truck driver told me to put the car in neutral with the engine on (to circulate tranny fluid). After towing the infamous ESP/BAS error warning came on. I have since tried to re-sync by turning the steering wheel all the left and right but it didn't work.
Could this form of towing have damaged something? (rear wheel tow w/tranny in neutral & engine on)
Any advice would be appreciated.
Rich...
. So go figure....I guess driving it a bit helped some how...
• Alternatively vehicle can be towed with drive axle lifted
• If this is not possible then vehicle can be towed (preferable with
a tow bar rather than a rope) under the following conditions / limitations:
1. Turn key to position 2
2. Selector lever to position ‘N’
3. Max. towing speed 31 mph
4. Max. towing distance 31 miles
Note: If towing speed or distance is exceeded, then further transmission
damage can occur.
