Satellite Radio in C230K
The only place I see room is in under the seats. I have power seats so I'll have to make some "paper-dolls" to check the clearances.
Are you installing it yourself?
I'd like to install my own as well.
I was thinking of getting the glass mounted antenna. Any advice on antennae?
heres a good link to look at all the antenna's, since I have tele-aid on the back I don't want to look like an FCC vehicle with a buncha antennas.
Antennas
https://mbworld.org/forum/w203/board/index.shtml
Pics of Todd's receiver
http://www.usstock.com/xm.htm
http://www.usstock.com/XM2.htm
http://www.clubxm.com/
I wrote sony a year ago and told them that they should make one of these interface via the unilink CD changer bus. But they shrugged it off. So anything I can do to help you steer away from them - let me know
P
The guy in Germany just emailed me that he has received the $$$$ and will be sending out my radio. I asked him if it's possible to get a manuel in English. In the meantime I downloaded one from PEET. Did you get one with your radio? Also did your radio operate OK or did you have to have your unit relooped (whatever that means)
I also received my Phillips Vison Plus bulbs today. According to the manuel there is some kind of clip that needs to be removed before you can take out the bulb. Any suggestions other than be careful. Like is there a trick to it?
I'm going to take before and after photos and will post them on the this site soon.
I tried Both the sony then the pioneer units in my car, and decided to keep the pioneer. I cut the rubber on the pod to make it only 1 inch (looks stupid as long as it is), and put the unit in the ashtray, drilling a hole behind it, looked great. Now the problem, I like music, i like music Loud or at least Somewhat loud and bottom line the FM transmitter just does not put out much power, so the max i could get out of it was what most cars sound like only halfway up. (also yes i had the unit set to max volume) I turned around and gave it to my mom for her CL and she loves it, maily because she hates loud music, more background. So unless you have a full system with amps, this will not please you... look into sirius system with minijack out for comand users, that's what i have in my current C.
cheers
1. Remove the large round black plastic cap by turning ~1/8 turn.
2. Reach into the headlight housing and grab onto the base of the electrical connector.
3. Turn it ~1/4 turn.
4. When it releases, pull it out. The bulb is attached.
5. Pull the bulb straight off the connector like a Christmas light bulb.
Remember not to touch the glass part of the bulb.
Do I understand you correctly in that I DO NOT undue the wire clips before removing the bulb? But rather only after I have pulled the bulb from the housing.
I'm a little confused. Isn't the wire clip holding the bulb in place?
Just want to do it right the first time..........thanks
Dan
To add to the confusion: the 1/4 turn mechanism is metal and I quess you could call it a clip in German-ese. And once it's removed you'll see that it's snapped onto the plastic connector body with tabs, but you don't have to unsnap that part. The bulb just slides out. You'll see.
It took me over 2 hours to do so make sure you are not in a rush.
2hrs?
I did this during my lunch break. And that includes reading the section in the manual 3 or 4 times. Maybe I got the "quick-release" headlight option.
