View Poll Results: MB & AMG wheels
AMG
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
OEM MB
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 OEM MB & AMG Wheel Thread - All you want to know
#352
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Any good wheel shop - Minimum 6 thread bite - Must be ball head bolts - not too long or will foul on rear.
#353
M37S
Do 2007 wheels fit on 2002?
I have wheels that fit perfect on 2007 c230. I have a friend that wants to buy my wheels for his 2002 c320.
I heard this would not be a problem as long as they were fine on my 07
#358
C180 Kompressor Saloon
CLS Wheels
just a quickie.
will the CLS wheels that are 8.5x18 and 9.5x18 fit on a 2004 w203 merc
the offset is ET28 at the front with a 245/40/18 tyre
the offset is ET33 on the rear with a 275/35/18 tyre
will i need to do anything to make these wheels fit.
please i need you expertess as i am picking these up tomorrow
thanks
thanks
#362
Super Moderator
Roger161 (03-12-2016)
#368
Moderator Alumni
Cant be done! jk
Check out my album detail - there is info there about the proper lugs you need to make this happen.
Im running 255 in the rear and I have no rubbing issues what so ever and ive got fat (not round) tire walls - Running 265 in the rear would probably scrape some though. 235 in the front just isnt going to happen, because I already rub the front fender linings when I turn....
#373
MBworld Guru
white and whiter
I might go back to 225 and 255 sooner than later. Hankook S1 EVO on tirerack is extremely cheap right now. $420 ish for a set of max performance tires. can't beat that. might buy and stock'em till need to change out the tires.
or i might go Sumitomo HTR Z III with 235 and 255.
#374
Super Moderator
#375
MBworld Guru
white and whiter
I'm still running 225/50/16 on stock suspension & I notice that I touch the fender liners now & again - both have a small shiney spot on them. SA built cars seem a little lower standard than I see in pics on the forum - they never have that nose in the air look - but still - lowering the nose must cause some severe rubbing at times.
been pretty aggressive with the PS2 and they're not too kind on tread wear...
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
