O2 Sensors
P0150 = O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
The others are misfire codes on those respective cylinders. Suggest you check your fuel filter & pump. Likely need plugs, wires & maybe coilpacks - Check by marking coilpacks & then interchanging to see if misfire changes cylinder. What mileage has the vehicle done?
See pics for O2 sensors. You have 4. O2 sensors have a life of approx 80K miles before they go out of spec & cycle to slowly. - All these problems can be triggered by fuel starvation.
