Aftermarket radio FM reception
dennis
javvy
First, used the recommended Scosche powered adapter and found different characteristics to the reception, depending on which antenna plug was connected (yellow or black). Reception was pretty much crap in either case.
Next, tried moving the power connection from the antenna adapter to pin 13 (black wire) on the radio connector. No difference.
Googled the matter extensively and found some VW guys having the same issue. Found mention of a DUAL WIRE antenna adapter. This takes BOTH antenna connectors and brings them down to the single standard antenna connector. Model is Connects2 CT27AA25. This item doesn't seem to be that widely available - I bought mine from a seller in the UK.
After installing this, reception is PERFECT - easily as good as OEM for both AM and FM stations. If you install this and reception isn't good the first time, just reverse the two antenna connectors. I didn't use or try the power lead on the adapter. I left the antenna wire on pin #13 of the radio connector, which seems to work just fine in this scenario. There may be a similar antenna adapter available without power lead - I would imagine this would work just as well with antenna power applied to pin #13.
http://www.amazon.com/Scosche-Volksw.../dp/B00009UHQQ
i currently have this and it does pretty much nothing
http://www.amazon.com/Metra-40-VW12-...ref=pd_sim_e21
