2005 C230 Differential oil?
If it is the axle making the noise it's too late & repair will be required. Does the sound change from trailing throttle to acceleration? If so pinion bearings have lost preload. If not & it's not tyres then it's diff carrier bearings or wheel bearings. Rear Axle oil does not lubricate wheel bearings.
Use only axle oils with MB approval 235.6 or 235.7 - Benz only approve one additive technology for their axles never mind what brand. DO NOT use non approved products.
