Engine Oil
Old Aug 16, 2009 | 04:35 PM
LightDragon's Avatar
w203 M111 E20 ML EVO
Engine Oil
What Engine Oil are u using for ur benz ? I vote for Kendall GT1 !
Old Aug 16, 2009 | 04:37 PM
jokerswld34's Avatar
05 c230 kompressor SS 6MT & 07 BMW 335i
royal purple 0w40 or 5w30. great stuff; you can feel the added performance and longevity.
Old Aug 16, 2009 | 04:40 PM
GT1 though is the king, give it a shot, it can undergo extreme temperatures, weights, velocity, never leaks ! it can reduce the friction and wear as well at the optimum level
Old Aug 16, 2009 | 07:24 PM
Dingleberry's Avatar
Marsaydees
Royal Purple is all hype.
M1 0W-40 here.
Old Aug 16, 2009 | 08:10 PM
The Ultimate solution to maintain a brand new engine through years is BARDAHL 2 OIL TREATMENT !
Old Aug 16, 2009 | 08:16 PM
skittles's Avatar
Moped
MOBIL1 5 W 40 M (specially made for mercedes)
Old Aug 16, 2009 | 08:21 PM
collector pal, try using the product ive mentioned in every oil change, you will be surprised...
Old Aug 16, 2009 | 08:47 PM
TNblkc230wz's Avatar
C320 Coupe
M1 0W-40 here.
Royal Purple is very good oil when used in the correct application.
I use Pentosynth 5w40. All W203s require oil meeting spec 229.3. 229.5 has supperceded it. Most off-the-shelf oil in the US does not. Certain Mobil One oils do, but not most.
Old Aug 16, 2009 | 08:50 PM
GT1 meets all the standards for mbs cars, it even exceeds the most required
Old Aug 17, 2009 | 12:27 AM
jogger's Avatar
02 S500
mobil 1 here
