W203 Coupe Parts - Performance Pulley & Stealth Box w/Sub & Amp
Rating: Thread Rating: 3 votes, 5.00 average.
Old Aug 22, 2009 | 01:33 PM
FORCEDINDUCTION's Avatar
2002 C230K, 1926 Model T Ford roadster hotrod, 1955 Buick Special, 1966 Chevy Truck, Custom chopper
Time to send some parts to a new owner. Feel free to email me at dave@mindmagma.com if you are interested in purchasing. All parts will ship from Florida (zip code 32222) and were removed from a 2002 C230 coupe w/Bose.
Thanks, Dave
1. Custom machined crank pulley to increase supercharger boost and inflate that "smiles per mile" ratio. Slightly larger than any other pulley offered on the market. GREATLY improves performance!! Belt included and no core charge, you keep your stock pulley! About 20K trouble-free miles it. No computer retune needed! Will fit 2000, 2001 & 2002 C230 Kompressor coupes, sedans and SLK's with the 2.3 liter engine.
$200 plus shipping
2. Wanna add some bass to your coupe, but don't want to lose any hatch space? Here's your answer. A custom made fiberglass enclosure with a Pioneer Premier 12" sub that fits in the stock Bose sub box space and Alpine MRV-T320 amp that fits inside your spare tire wheel. Dramatically improves the sound without loosing any space at all! Includes all Monster Cable wires and Pac high to low level converter for an easy 3 wire hook up. I can help with wire colors and placement if needed. These were listened to at "conservative volumes", but tested to reveal surprisingly high output and sound quality. I am positive you will be very pleasantly surprised! Surely this could also be installed in a non-Bose coupe also, but wire hookups will most likely vary and could require a longer RCA cable.
$450 plus shipping (shown installed for proof of stealth fitment)
Alpine MRV-T320 amp specs and features :
• Max Power (EIAJ) 140Wx2 (4ohm; Stereo) 400Wx1 (Bridged 4ohm
• 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 50Wx2 2ohm; Stereo (0.3% THD) 80x2 Bridged 4ohm; (0.3% THD) 160x1
•14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 80Wx2 2ohm; Stereo (0.3% THD) 110x2 Bridged 4ohm; (0.3% THD) 220x1
Bass Engine® features:
•variable 15-400 Hz high-pass/30-400 Hz low-pass crossover, 12 dB/octave
•variable Bass EQ (0-12 dB of boost at 50 Hz)
•S/N Ratio 100dBA
•Frequency Response: 10-50kHz
•12dB HP/LP Crossover
•Speaker Level Input
•Bass EQ Circuit
•Extra Large Gold Plated Terminals with Wire Insert Capability
•Top Panel Power LED
•Continuously Adjustable Crossovers
•DC Straight, STAR Topology
•DC-DC/PWM MOSFET Power Supply
3. Clear front corners. Car not included.
$20 plus shipping
Old Aug 22, 2009 | 01:38 PM
M-bENZ's Avatar
Corrolla
How much you want for the amp only ?
Andy
Old Aug 22, 2009 | 01:56 PM
Hi Andy,
I honestly hadn't thought of selling the amp separate from the sub & enclosure as they have been matched to work with each other (i.e. gains, inputs and eq's set). I just figured it would be a nice "plug and play" setup for anyone looking to add bass to their coupe. Hit me up with a PM though as I may have something that might work for you.
Regards, Dave
Old Aug 22, 2009 | 02:14 PM
jturkel's Avatar
02 C32 AMG
dave
for clarification purposes, is that a crank pulley or a supercharger pulley? they are NOT the same thing.
supercharger pulley is machine down and sits on s/c to get more boost
crank pulley sits on crank and is larger to generate more boost and to spin s/c pulley faster
Old Aug 22, 2009 | 02:26 PM
That is the pulley that installs on the crank that spins all the accessories from the ribbed area closest to the block and spins the supercharger from the ribbed area closest to the radiator. It is essentially a 2 tiered pulley.
The accessory ribbed area has not been modified from the stock diameter.
The aluminum ring near the front of the pulley has been machined to accept a ribbed serpentine belt that spins the supercharger. The black part of the pulley shows the stock diameter. This pulley works with the stock supercharger pulley just as the ASP performance pulley does. I have altered my original post in hopes of a more correct description. Sorry for any confusion.
Nice "signature movie" BTW!
Old Aug 22, 2009 | 09:56 PM
thetikicentral's Avatar
2005 Mercedes Benz C230 Kompressor Sport
would that pulley fit my 05 c230k ss?
Old Aug 23, 2009 | 10:18 AM
I'm pretty sure that the crank pulley will only fit 2.3 liter engines. Sorry.
I believe the 2.3 liter engines were in 2000, 2001 and 2002 coupes, sedans and SLK's.
Old Aug 30, 2009 | 01:10 AM
Anyone? Offers?
Old Nov 3, 2009 | 06:42 PM
Chitownbenzo's Avatar
2002 c230 Kompressor Sport Coupe
I was wondering if maybe you can build that enclosure for my benz? and if it is possible to build one for the left side as well?
Old Nov 3, 2009 | 07:00 PM
XsuperbeeX's Avatar
C320 coupe
no more 4 subs?
Old Nov 3, 2009 | 08:47 PM
LinDenKid's Avatar
C230 coupe 2002
What are the HP/TQ Gains with this pulley?. you got PM.
Old Nov 4, 2009 | 12:25 AM
drb930's Avatar
2005 C230 Sport Coupe
Dave,
How is the aluminum adapter ring attached to the stock dampener?
Thanks,
Dave
Old Nov 14, 2009 | 03:25 PM
jagsy's Avatar
2002 C230 Kompressor, Capri Blue
Dave,
I live in jax too. My 02 has about 53k miles and I would like to see what else I could get for it. Please let me know.
Thanks,
Wayne
Old Nov 14, 2009 | 09:18 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Any pics of the sub uninstalled? Might be interested, but would like to see more pics of the assembly if possible, showing mounting pts., etc.
No problems with heat build-up in the amp? Did you run the amp in that location with all of the normal parts of the floor on top of it?
Old Nov 15, 2009 | 10:31 AM
LinDenKid's Avatar
C230 coupe 2002
I'm interested in the pulley, emailed him, pm'ed him. Nothing yet.
Old Nov 16, 2009 | 03:01 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Tommy, I can't speak to how the Alpine amp will perform, but I have a Phonenix Gold Xenon in that space. Works fine for me.
Ed
Old Nov 16, 2009 | 04:35 PM
tommy's Avatar
Thanks for the info, Ed.
Old Dec 8, 2009 | 06:19 AM
mr merc's Avatar
2002 c230 coupe w203
who machine the pulley,what are the specs and to what does it increase the boost
Old Dec 18, 2009 | 09:06 PM
Hksuperman4000's Avatar
C320 Sports Coupe 2003
How much for just the box for the sub
Old Jan 9, 2010 | 10:47 AM
mygirlscoupe's Avatar
2004 c230 coupe
Are the clear marker lights still available?
Old May 24, 2010 | 05:32 AM
victorbrad's Avatar
1998 BMW
after i recently purchased the 1964 chevy truck i was thinking of buying something similar. good pics by the way.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
