Rain Sensors
Old Aug 28, 2009 | 11:05 AM
krisv420's Avatar
02 C320 Sedan
Rain Sensors
Hey Everyone...
I just got back from camping and i was messing around with my car and i found out that my car has rain sensors... What i did is i checked my vin number.. and it told me all the options i have on my car.. I also went to the dealer to have them look.. They also said i have rain sensors...
But the rain sensors don't work.. ill flip the knob to position 1 And they still come on by them selfs.. I dunno if its the sensor... Or a bad windshield that was replaced when i got bricks tossed through it..
Ive taken the sensor apart and tried cleaning it.. but no go.. Ive searched and found nothing about rain sensors.. anyone wanna chime in.. I think this is a cool feature thats a must.. Just like rolling up the windows with your key fob..
Thx
Kris
Old Aug 28, 2009 | 11:12 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
When I had my windshield replaced, my rain sensing wipers worked, but not near as good as they did before the replacement. So, when my car was in for warranty work, I had them "recalibrate" the rain sensor, and after that, they worked perfectly again. Maybe you need to take it to the dealer and have them hook up STAR and recalibrate the rain sensor.
Old Aug 28, 2009 | 11:22 AM
krisv420's Avatar
02 C320 Sedan
Hmmm that sounds like a good idea if my car was still under warranty ..
Thanks for the info
Old Aug 28, 2009 | 11:28 AM
johnand's Avatar
Super Moderator
Thanks for the info
I had to pay for it, since it wasn't a warranty issue. It cost a whole whopping $18. It literally took them about 5 minutes.
Old Aug 28, 2009 | 11:57 AM
Glyn M Ruck's Avatar
Super Moderator
https://mbworld.org/forums/attachmen...0sensor-1-.pdf
https://mbworld.org/forums/attachmen...sensor3-1-.pdf
https://mbworld.org/forums/attachmen...sensor2-1-.pdf
Listen to Johnand
Old Aug 28, 2009 | 01:00 PM
krisv420's Avatar
02 C320 Sedan
Fixed the rain sensors WOOOT this is so cool ive never seen anything so dope before...
The issue was the unit wasn't making full contact with the windshield... all i did was push it on harder and it works perfect now =P heres a picture of it
The unit on the right wasn't fully on the windshield...
But im still trippin about the air bubble if you guys can see it..
Old Aug 28, 2009 | 02:19 PM
Utahkompressor's Avatar
W124, W203, W204, W251
....just curious???
What the different between the new sensor(lots of dots) and the old sensor(look like blue screen with lens)?
Old Aug 28, 2009 | 03:00 PM
krisv420's Avatar
02 C320 Sedan
Originally Posted by Utahkompressor
....just curious???
I think maybe the newer ones have more little sensors built in to that big unit
Old Aug 28, 2009 | 05:17 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Well at least you got it fixed. Although even when they work as designed, they only half-*** work. They're too aggressive in my car.
Old Aug 28, 2009 | 06:12 PM
Super Moderator
Matt. As long as the sensor has intimate contact with the screen, as Kris has learnt, & the outside of the screen is free of - mineral, salt or silicone deposits - The dealer can adjust sensitivity with the STAR to your liking. (within reason)
Old Aug 28, 2009 | 09:15 PM
holycaoAMG's Avatar
A Car
On the second pic, is that where the light sensor is located too? (for auto headlights?)
Old Aug 28, 2009 | 09:26 PM
Super Moderator
Yes
Old Aug 28, 2009 | 09:56 PM
Dingleberry's Avatar
Marsaydees
I cannot believe this...
I just popped off the cover to see if I have the rain sensor. Much to my surprise... I DON'T!! There's just a blank spot where it should be and to the left is the headlight sensor.
Why on earth would my car not have it? It has factory xenons and navigation.
Is it possible to put a rain sensor in? Easy/Hard?
Old Aug 28, 2009 | 10:30 PM
Marsaydees
Somebody said they just plugged one up without changing the windshield and it worked.
https://mbworld.org/forums/1230733-post25.html
thoughts?
Old Aug 29, 2009 | 01:28 AM
samaritrey's Avatar
Super Moderator
THE C350
go to cars.com and go to research. it was an option on the 02 c32 i know that but don't know much about option packages. my dad had a fully loaded 02 c32 and it had rain sensor.
Old Aug 29, 2009 | 03:51 AM
LILBENZ230's Avatar
It was bundled with the sunroof in later years.
Old Aug 29, 2009 | 06:02 AM
Super Moderator
If you have the clear area in your glass & if you have the correct wiring harness & a compatible wiper controller. It is my understanding that you can have it adapted with the STAR.
Old Aug 29, 2009 | 11:48 AM
SUNILP's Avatar
2015 E250D
On preupdated C class cars, there are 2 different sensors. One for headlights and one for the wipers. On 2005 and later cars, there is 1 sensor that controls both items. The lens for the sensor comes affixed from factory to the windsheild. There is no way to get that part alone. You have to replace the windsheild to get a new lens. The air bubble can cause a malfunction in the rain sensor.
Old Aug 29, 2009 | 11:51 AM
SUNILP's Avatar
2015 E250D
Your car either had one of the following
1. had a sensor from factory and someone replaced the windshield with a non sensor glass without lens
2. never had it from factory.
In case of no. 2, it can be added provided you get a windsheild with lens, short harness to overhead control panel, and programming in the EIS
Old Aug 29, 2009 | 07:03 PM
Super Moderator
Thanks a lot for clarifying the issue. It is obvious that my knowledge is only for pre updated cars. Appreciate your teaching me.
Old Aug 30, 2009 | 11:23 AM
SUNILP's Avatar
2015 E250D
Anytime
Old Sep 1, 2009 | 02:59 AM
R6Tuan's Avatar
2006 C230 Sedan
when i put my wipers on auto, i notice that went theres light rain, sometimes my wipers will go at almost full speed. its pretty annoying.
will a recalibration help? can i ask them to turn down the sensitivity of my rain sensors?
its got to the point where ill just press the mist button instead on leaving it on auto
Old Sep 1, 2009 | 07:22 AM
Super Moderator
Yes - See Johnand's post
Old Sep 17, 2011 | 07:40 PM
WaveyKat's Avatar
Something Slow
so i think my rain Sensor stop working.. when i turn the stalk to position1. the wipers will keep wiping like its in postion #2 and there no rain! nothing on the glass.... so i purchased a new Sensor and installed it also check the FUSE #9 which was good... now when i turn to postion #1 the wipers will wipe Everything 5-10 seconds.. i hooked up the DAS and for some reason there no communication to the Rain Sensor :-(.. can anyone help?
Old Oct 10, 2012 | 09:18 AM
WaveyKat's Avatar
Something Slow
bump anyone? i switched out my Overhead Contol panel to make sure that wasnt the problem still its not working
