C200kompressor engine problem
Rating: Thread Rating: 2 votes, 5.00 average.
Old Sep 4, 2009 | 04:17 PM
Mb_racing's Avatar
w211 e55 and w203 200k and bmw e46 325i
Question C200kompressor engine problem
Hello. I have an Engine problem with my Mercedes so I hope that I can get som good answers here.
It was today when I started the engine, it's starting but not directly and when the engine runs it's infirm when I drive, it was a very rainy day today, I have changed the air-mass sensor one week ago. Anyone who can help me found out what's wrong?
Old Sep 4, 2009 | 05:24 PM
Glyn M Ruck's Avatar
Super Moderator
Welcome - please complete your profile - where are you? - with a C200, obviously not USA.
Please give us some more information about your problem - Don't understand "infirm"?? What is the engine doing that you don't like? Why did you change the MAF? Did you replace with a genuine MAF? Do you have an OBDII scanner? Is your car throwing any codes?
If English is not your first language, don't worry - we will help.
We need more information
Old Sep 4, 2009 | 05:56 PM
Mb_racing's Avatar
I'm from Sweden.
I mean that when I start the car, it feels weak and it only wants to die.
I changed the MAF because it was broken, and yes it was a genuine part.Im going to check the codes when I get a scanner. I was thinking if there is some regular problems on those? If anyone else has had problem with this?
Old Sep 4, 2009 | 07:19 PM
Super Moderator
Please check the part number on the MAF. It is on the black plastic cover. VW/Audi MAFs look identical but don't work on a Benz. Please get a scanner & check for codes. It stops a lot of guessing.
What year is your car & what mileage has it done? The most common problems on the M271 engine are head problems - worse on 2003 models. Deposits build up on valves & cause them to leak & burn & in the combustion chambers causing detonation & misfires. This happens less on high grade European fuels. The other common problem on the M111 & even more so on the M271 is oil leaking out of the cam sensors on the front of the engine. Pull the sensor plugs off & look for oil. This gets in the wiring harness & messes with the electronics. First thing to suffer is usually the O2 sensors because they are low down. When oil gets down to the O2 sensors they send wrong information to the ECU & mess up the fuel trim. Do a search for leaking cam sensors & read the DIY stickies at the start of this forum. A huge amount has been written about the problem. I will try & find a link for you. Benz have a fix for this by replacing the sensors & fitting pigtales to stop oil getting into the engine harness.
Do a throttle reset.
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
We are guessing. Download the OBDII codes with a scanner and let us know.
See my pictures on post number 21 on this thread
https://mbworld.org/forums/c-class-w...e-problem.html
Good Luck
Old Sep 5, 2009 | 04:02 PM
Mb_racing's Avatar
Good Luck
Hi. It's from the year of 2001, and it has run 210.000 km. I have checked the cam sensor, I found out that it's leaking oil into the plug, can it be the problem? I will get a scanner on tuesday, so I will return with answer from the scanner then
Old Sep 5, 2009 | 04:24 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Leaking cam sensors can be the issue.. but as Glyn said, you need to read the codes to know for sure.
Old Sep 5, 2009 | 05:58 PM
Super Moderator
Ok - M111 engine with one cam sensor. Yes it can be the problem. You must stop the leak by replacing the sensor & clean or replace the engine harness. Read those codes & let us know.
Old Sep 9, 2009 | 05:46 AM
Mb_racing's Avatar
Hello. i have read the ODBII codes and it says = Missfire cylinderbank 1. i have change the cam sensor without influence :S
Old Sep 9, 2009 | 05:48 AM
Mb_racing's Avatar
its also new sparkplugs one week ago
Old Sep 9, 2009 | 07:41 AM
Super Moderator
OK - then likely lead or on plug coilpack failure. At your mileage I recommend new leads & coils
Old Sep 9, 2009 | 07:43 AM
Super Moderator
You can try moving the leads & coils around to see which is the offending lead & coil by seeing if the misfire code changes cylinder. I would change them
Old Sep 9, 2009 | 08:31 AM
Mb_racing's Avatar
I order already coilpack, get them tomorrow. I find some leakage in EXHAUST MANIFOLD. I welded that today
Old Sep 15, 2009 | 04:32 PM
Mb_racing's Avatar
I changed the coilpack, the car run perfectly fine for one day only. Now it has turned out to be a new problem,
it runs very badly when I've just started the engine, and it don't want to go up in RPM, even if I have full throttle.
It also doesn't give any OBDII codes.
Old Sep 15, 2009 | 05:28 PM
Super Moderator
It could be a crankshaft position sensor that's failed or is failing.
First thing to do is go back & check everything you have touched. When new things occur when you have just worked on a car the first suspicion has to be that you have disturbed something.
Good luck!
Old Sep 15, 2009 | 05:52 PM
Mb_racing's Avatar
THe car run sometimes up to RPM as it should do.
It doesn't run equally bad when I drive with the manually transmission.
I have checked and everything looks like it should be, have also searched after leakage with the motor starter in intake
Old Sep 16, 2009 | 04:19 PM
Mb_racing's Avatar
anyone who has any idea?
Old Sep 17, 2009 | 07:40 PM
Super Moderator
PM C230 Sport Coup. He knows the M111 engine very well.
Old Sep 19, 2009 | 04:03 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Well, what codes are you getting now? No more misfire?
The fact that you have a HOLE in your exhaust manifold, means it must have gotten very hot, and typically there's one thing that causes that, and also causes misfires.
The catalytic converter may be clogged...?
Do they use those in Sweden?
and as Glyn says "First thing to do is go back & check everything you have touched. When new things occur when you have just worked on a car the first suspicion has to be that you have disturbed something."
When you start replacing parts randomly, you can have problems.
How many miles on your car?
Other thing you can check is the "recirculating air valve".
Remove the air filter box, it will be visible.
There's a trick to reset it.
1 When ignition is switched off press flap slightly past limphome
position. (NOTE: Which means push it with your finger and hole it while someone turn the ignition on, but don't start the engine. You will see it move and reset itself)
90° position must be changed manually.The processor
shut-off delay has a duration of approx. 5 seconds.
2 Switch on ignition for approx. 15 seconds, switch ignition
back off again and wait for processor shut-off delay.
3 Switch ignition on for approx. 45 seconds, switch ignition
The learn-in procedure for the recirculated air flap is then
completed.
AF07.61-
Old Sep 19, 2009 | 04:53 PM
Super Moderator
Thanks Todd - could well be a clogged cat & yes they most certainly have them in Sweden
Old Sep 20, 2009 | 02:37 PM
Mb_racing's Avatar
I don't have any codes no more at all. Yes we use catalytic, I will check it on tuesday when I return home.
The car has run 210.000 km, I don't know how to return that into miles.
It have an so called sequentronic gearbox and I'm wondering why it run mutch weaker when I use automatic, than with the manually.
Old Sep 22, 2009 | 03:15 PM
Mb_racing's Avatar
completed.
AF07.61-
Hi again,
I've checked the catalyc today, and everything looks like it should be, also the O2sensors gives signal.
The engine start and run a few seconds and then dies, even if hold full throttle.
The fuel pump works for a while when I turn on the ignition, but then after a while I does'nt hear anything from it, even if the engine is running.
Old Sep 22, 2009 | 04:57 PM
Super Moderator
OK. We need to check for clogged fuel filter & pump operation
When last was the fuel filter replaced? - Change it.
If the car has been standing for a while & you turn on the ignition - you should hear the pump start - build up pressure & then stop & the car is ready for starting. When the engine is running the pump should run continuously - Some people like me can hear it. Some seem not to. Check the fuel pump pressure - s/b approximately 50 psi. You can do this prior the the front injector pump on your engine. The pump is under a round cover plate under the lower back seat on the LHS.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
