Check Engine Problem
Old Jan 11, 2008 | 05:49 PM
willcedes's Avatar
05 c230
i have an 05 c230K
recently my Check engine light came on.
I ran the codes with an OBDII reader and the error came up
Engine Running lean (bank 1)
is this a serious problem or can i still drive it till next week when i have an appt at the dealership?
Thanks for the info.
Old Jan 11, 2008 | 07:15 PM
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
What are the symptoms of your car? Are there any, or do you just have the check engine light?
Old Jan 11, 2008 | 07:28 PM
willcedes's Avatar
05 c230
no symptoms. the car seems to drive normal other than the check engine light came on with that error of running lean.
hope that clarifies?
Old Nov 6, 2008 | 01:06 AM
dbvolz's Avatar
2018 C63s
Anybody? I'm having similar problems...
Old Nov 6, 2008 | 01:06 PM
PA_Pete's Avatar
2001 C320
Running lean? Sounds like maybe an air leak somewhere.
Old Nov 6, 2008 | 01:49 PM
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by willcedes
i have an 05 c230K
What mileage has the car done - this is a fuel trim warning - You can drive till next week - just don't go on a 1000 mile trip. May be an O2 sensor or MAF problem. Can try unplugging the MAF - get it properly diagnosed.
Old Nov 6, 2008 | 02:21 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
This is most likely the MAF. You can drive it, just don't do any hard throttling of the car. BABY the car.
E
Old Nov 6, 2008 | 02:25 PM
brabus86's Avatar
c320
i have the same problem to, i can drive but the check engine light up for month now on my car, seem like it okay, but again i do not know what's the problem. should i be worries?
Old Nov 6, 2008 | 03:00 PM
Super Moderator
Borrow or buy a 70 buck OBDII/CAN reader from Kragens and check what codes come up. It might be minor but you can do damage by ignoring it. Run too lean for too long & you can hole a piston.
Old Nov 6, 2008 | 05:33 PM
dbvolz's Avatar
2018 C63s
My light has only been on since last night. I took the car by the dealer today and the tech said the error comes up as an "adaptation error" he said it was the air/fuel mixture and it may be as small as a little sensor or the whole MAF. If it's the MAF, does anybody know how much that costs? Is it something they have to do, or is it a possible DIY job?
Old Nov 6, 2008 | 05:37 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Do a google search on "Mercedes OEM auto parts" and you should get several sites that sell the MAF for your car...It'll give you an idea of the part cost even if you decide to go to MB for the repair...
Old Nov 6, 2008 | 05:38 PM
amanonfire's Avatar
W203
Check your cam sensors, I'll bet $5 they are leaking cause running lean is one of the first indications as it fouls the connection to the O2 sensors.
There's a thread on how to check them, STF.
Its not serious that you shouldn't drive the car, yet unless you are under warranty or can DIY, the fix is pricey!
Old Nov 6, 2008 | 06:27 PM
Super Moderator
It's a DIY. Go here
https://mbworld.org/forums/c-class-w203/206492-diy-m271-maf-replacement.html
Old Nov 6, 2008 | 06:43 PM
Super Moderator
Guys - see this - it covers all your questions
Old Nov 7, 2008 | 11:44 AM
amanonfire's Avatar
W203
Don't it it, I made this mistake and replaced MAF and both O2 sensors only to find out it was the cam sensors leaking.
CHECK THOSE FIRST!
Old Nov 7, 2008 | 01:48 PM
dbvolz's Avatar
2018 C63s
Thanks for all the info guys! I have the following dilemma: I recently had to replace the alternator pulley due to faulty bearings: cost me around $520. Now I have an appointment next week to get my Check Engine situation looked at. The tech guessed it was probably either the MAF or O2 sensors, but without further investigating he couldn't tell. Also, I have a Blower Regulator issue as well as a broken passenger door pull. Basically I'm guessing I'm going to end up easily paying over a $1000 for all this. (Just a ballpark) Now I ask you guys this: is it worth buying an extended warranty? I thought that problems like these would come much later down the road since I'm only 5000 miles out of warranty. Most warranties are around $3000. Any feedback would be greatly appreciated!
Old Nov 7, 2008 | 02:03 PM
mleskovar's Avatar
'17 Jaguar XF
.... is it worth buying an extended warranty? ...
Yes.
Old Nov 7, 2008 | 02:21 PM
amanonfire's Avatar
W203
Please, for the love of god, check your cam sensors. 50K miles is about when the leak becomes a problem, and MAF/O2 sensor issues are a common misdiagnosis.
It takes 2 mins to check them, pop the hood, pop off the connector, look for oil.
Do NOT trust the tech to find this. Te techs at the dealership I go to changed my O2 sensors despite them DRIPPING oil out of the connector!
It'll save you $500 ($300 for new MAF, $100 each for O2s) which you'll need for a new engine harness ($350).
Old Nov 7, 2008 | 02:22 PM
amanonfire's Avatar
W203
Originally Posted by mleskovar
Yes.
Usually: no
On these cars: YES
Old Nov 7, 2008 | 03:13 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Originally Posted by amanonfire
Usually: no
On these cars: YES
Agreed. I definitely got my money's worth.
Old Nov 7, 2008 | 04:13 PM
Super Moderator
amanonfire is correct - it could be the cam sensors - here - let us know
Do the pigtales
Check for oil leaks
amanonfire - calm down & people will listen!!!
Attached Thumbnails Check Engine Problem-engine1.jpg   Check Engine Problem-fix0.jpg   Check Engine Problem-fix1.jpg   Check Engine Problem-fix2.jpg   Check Engine Problem-0117081609.jpg
Old Nov 7, 2008 | 06:20 PM
amanonfire's Avatar
W203
Nah, I'm just going to post more "I told ya so"s and laugh at wasted money on repairs.
Old Nov 8, 2008 | 10:15 AM
dbvolz's Avatar
2018 C63s
Do the pigtales
Ok, so I just unplug these sensors to see if there's a leak? Thanks for the pics, at least now I know where to look. From what I understand, I would be unplugging the sensors and pluggin in the part labeled "starter line"? Don't seem to follow you. Is this something I can replace myself? Also, I still have the blower regulator problem. You guys think it makes more sense to replace the cam sensors (if they are the problem) myself and try to get an independent to change the regulator? Or just get the warranty?
Oh, I just checked the price for the Cam sensors, apparently OEM is $159 and Bosch is $89 and a company called Vemo only $70
Old Nov 8, 2008 | 01:20 PM
Super Moderator
If you are going to keep the car I would get the warrantee.
Anyway - just uplug the sensors and see if everything is full of oil. It works it's way down the harness and messes with the O2 sensor readings. You can change the sensors yourself if they are leaking and attach the pigtales that Benz devised as a fix. Then if the new ones leak they mess up the pigtales & not a major piece of wiring harness. I would not do anything until you see if the sensors are leaking or not - it might be a red herring.
Once diagnosed then you can make decisions. This is all covered in detail on this forum if you search - I am however quite prepared to help if I can - no problem. Check those cam sensors.
Old Nov 8, 2008 | 04:00 PM
dbvolz's Avatar
2018 C63s
Glyn & Amanonfire: Thank you! I just checked my cam sensors, one was ok, but the other had oil in it! Wow, would have never thought to check these! I literally had my CEL come on Wednesday night, and have hardly driven the car since then. So I figure I will order the cam sensors and pigtails and install these myself. Right? I figure the sensors can't be too hard to install...
Also, I'm still thinking of getting a warranty and then eventually claiming my A/C blower regulator on that since its not such a priority with winter coming and all... Any advice on the warranty? Who to go with?
