Need HELP... Having a PROBLEM
Old Sep 18, 2009 | 04:38 AM
XsuperbeeX's Avatar
C320 coupe
Problem with my steering... My left front tire blown and I was like draggin about no more than 0.5 mile... now my steering is a bit shaking sometimes over 80mph... some times can feel it when around 75mph... what could be the problem? (and I just lower my car)
1. Bent wheel?
2. Different tire?
3. because of the drop? (even though sound stupid)
4. shock gone?
5. other suspension part? (hopefully not this one )
Old Sep 18, 2009 | 12:40 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
1. Bent wheel?
2. Different tire?
4. shock gone?
STFF NOOB. Just kidding.
You have replaced the tire?
-I know it seems stupid, but check to make sure your lug bolts are tightened to spec first.
-If you just had a punctured tire and it's repaired, it might have a bubble. Check for bubbles.
-If you had the tire replaced, get a tire balance done - this is one of the simplest/cheapest fixes for high speed steering shake.
-If that doesn't solve it you might possibly need an alignment.
Hope these suggestions help. Let us know the resolution!
Old Sep 18, 2009 | 01:07 PM
Norwichdelta06's Avatar
2007 c230
Make sure you to go a reputable shop that has a high speed balancer or road force balancer. Road force balancer is the best one out there. But another stupid question is that the guy could've remounted the tire backwards (if u have unidirectional...which most sport cars do). Do you feel the shake in the steering wheel and/or just the seat?
Old Sep 18, 2009 | 04:17 PM
XsuperbeeX's Avatar
C320 coupe
steering wheel only... actually got another solution.. 6. Being paranoid...
should I just go the dealer since I still have the warranty?
Old Sep 18, 2009 | 05:29 PM
2007 c230
no because whatever mercedes charges for a diagnostic problem what 110/HR? U could get all 4 of your tires roadforce balanced.
http://www.gsp9700.com/pub/search/findgsp9700.cfm
http://www.gsp9700.com/pub/features/how-5.cfm
there's the search to find the cloest one for u
Old Sep 19, 2009 | 10:17 AM
Glyn M Ruck's Avatar
Super Moderator
Check wheel for runout - tyre off
Check tyre for runout - mounted
Check tyre correctly mounted - If correct & there is runout either replace or grind to round if out of round. If runout is horizontal replace tyre.
Check tyre for delamination as LILBENZ say's.
Check hub for rust & debris - lightly apply Coppaslip or similar
Torque wheel in correct sequence
Have wheel balanced properly (roadforce/high speed) - whatever
Have wheel finish balanced on car if necessary.
Make sure you balance the RHS wheel as well with equal rigor..
