How to read error codes?
2002 Mercedes Benz C230 Coupe
Hi all,
Ive read a lot on the forums about error codes, but for the life of me I cant figure out how to read these error codes.
Is there a code reader that is required? If so, what type should i be looking for? Any recommended brands/models?
Any help is appreciated guys. I apologize for the noobish question.
And before the search ***** bust out their STFF replies, please note that ive serached using the following keywords:
search error code
read error code
error code reader
error code
error
code
Try it out if you don't believe me.
Thanks.
search error code
read error code
error code reader
error code
error
code
Thanks.
Yes, OBDII compliant reader. Any one that can read and clear codes. The cheapest one ($30? now). It plugs in under the dash around the steering column. It displays a code which you cross reference to a failure cause.
MBworld Guru
white and whiter
read the threads you find and you'll always see OBDII scanner/reader being mentioned.
cheap one only reads the code while the more expensive ones will give you the code and the name of the error.
so far, I've seen most C32 E55 people using Innova OBD scanners.
OR if you have an iPhone... video from Overdrive http://www.youtube.com/watch?v=91aPZiBNzf4 ...which is what i'm using that also has a code reader built into the functions. using REV with PLX Kiwi Wi-fi
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Cheap one from Kragens/PartsAmerica that tells you what the code means too. (highly recommended by Johnand)
![](https://mbworld.org/forums/attachments/c-class-w203/166131d1253439286-how-read-error-codes-gascap4.jpg)
More expensive Equus Innova 3130 or better. (what I use)
![](https://mbworld.org/forums/attachments/c-class-w203/149277d1234218907-very-rough-start-up-idle-mornings-when-cold-cel-equus3130-1-lg.jpg)
Thanks for all the info guys. Im going to look into the scanners....definitely need one. Can these scanners also be used to clear the service A/B errors as well or are different scanners required for those?
Thanks.
Thanks for the suggestions Glyn. Im going to look into getting one of those.
Thanks Frank, although I think a regular scanner would be more appropriate than the iphone app and the wireless transmitter. I guess its way cooler and it gives you more features like the intake temp etc. Thanks anyway.
Thanks.
For the Service message (A/B) you don't need a scanner.
Here is how to reset it:
Switch ignition on. The standard display of the control system appears. Press the up or down button on the multifunction steering wheel until the Service indicator appears in the multifunction display.
Press and hold the reset button for about four seconds. This message will appear in the multifunction display: SERVICE INTERVAL.... RESET WITH R BUTTON FOR 3 SEC.
MBworld Guru
white and whiter
Thanks.
Thanks.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
MBworld Guru
white and whiter
I do have an iPhone 3GS and the iPhone app is a great option, but I think instead of spending money on the Bluetooth wireless unit, of rather buy a more reputable brand/model scanner, espeially for somethig I'm only going to use once in a way. Btw I saw some pics of your w204 on the other forum. Looks terrific! I'm considering gifting the w203 to my parents for their anniversary and getting myself a 204. Since you own both, I'll be bugging you with comparison questions if you done mind...lol![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Super Moderator
Both of those will work.
Last one is just basic (tell you code then you have to look up the code to see what is wrong) while the first one will tell you the code and what is wrong.
http://www.obd-codes.com/trouble_codes/
Thanks for the link Karo
