Door check is a "wear and tear" item!? Dealer is crazy.
( Paying for mods is cheap when you don't have a monthly payment or insurance to worry about. )
But i guess a lot of people had there stuff givin to them.. sucks for the people that actually have to work 10 hours a day for it.
Karo, I agree with you wholeheartedly.
Matt, I apologize for my spelling, but at least I can spell given.
Paying cash for a several-year-old used car is "making it rain"? Did you give them "$500 in $1s?"
No one forced you to spend money on a used Benz. So how does it suck to have to work and pay for it? Oh yeah.. cause stuff like work interferes with more important other things - like getting high. Right? Not my business, is it? Neither is it your business to post stuff like this, talking out your *** and giving grief to someone who happens to have it better than you - partially due to circumstance, and judging by the intelligence difference I see - mostly due to better decisions.Give me a break.
the "I want to speak with your manager" works 99% of the time.
The most diffcult part was to remove the door panel. There are several clips whcih attched the door panel to the door.
I didn't know you could use hot water to soak the metal bar.
But again, thanks for a good replacement reading material.
Removing the door panel is easy once you've done it once.
Turns from a question to a slanging match!
You better check yo'self before you wreck yo'self, a door of it's hinge is bad for your health!!!
LOL
read it and weep!
I suppose no one has heard of it, because it wasn't something I ended up posting about...
small annoyance, not worth posting, well if i was being quoted labor like yours, I would post.
Somehow the metal had actually cracked at the mounting point.
It was grinding into the body, slipping side to side, and scratching the paint.
It's just the kind of thing that comes back to bite you down the road, corrosion etc.
And it was popping etc.
FYI- Part number on the coupe (not sure if they're the same on sedan)
are A2037200316 Door stop
N000000000944 Bolt for door stop M6x20 $.75
So as stated, it was about 50 bucks for the part.
It took, oh maybe 1/2 hour to replace.
You have to fish it in and out, and it's like one of those puzzles.
I think I had to open the new one a notch to get to feed through, and you have to
pull it this way, then that kinda thing through the door panel....I think I had to
pull the door speaker too to reach it.
Not a big deal, but it does take a bit of doing to fish it through, but it will go.
I also ended up ordering new screws, the old ones didn't seem to tighten down enough, and I also ended up breaking one, and then having to use to easyout to get the screw out.
Works great now. So I would recommend new screws.
See my sig, thats my driveway, that probably how I broke it, must've let the door go by accident.
I'd highly recommend just buying the part, and DIY'ing.
There's a pdf for taking the panel off I posted in a thead
by username Gaeix about removing the door panel . Or is it Geaix?
Something like that.
FYI- the drink holder comes out easily....remove the rubber piece in the bottom, it just pries out.
Then it unclips back to front.
When it gets sticky, doesn't want to open etc.
I found that it just get gunked up.
Soak it in hot water for a few miinutes, let it dry, and just like new, pop it back in.
Just did this a day or so ago...was getting hard to open, and wouldn't latch.
Like new again.
I bought a new one for that reason, turned out the old was OK after soaking it, sold it to a forum member!
No hes correct. I tried to rent a car from enterprise and you have to be 25. If the MB dealer is linked to enterprise which some are in so cal.. Cough Hoehn carlsbad it kinda sucks.. But yet this post is so old
2037200316 would be the pn to seach.
But check it on epc 1st may have changed and may be different one door to the other.
Also the parts site sponsored here has it for about 50.
http://www.mymercedesparts.com/partl...&siteid=215326
If possible avoid parts.com high shipping cost.
