M272 Do It Yourself
Old 10-03-2009, 05:20 AM
W203E35's Avatar
2006 C350 Sport 6MT
M272 Do It Yourself
What's a good way to give back to the community? Post instructions on how to do maintenance the same way MB techs do.
Open Engine Hood and Move to Upright Position and Close
http://i37.tinypic.com/2hhhnrs.jpg
Removing/Installing Air Filter Housing
http://i33.tinypic.com/rr1u8o.jpg
Removing/Installing Air Pump
http://i37.tinypic.com/ih5m2r.jpg
http://i35.tinypic.com/wqwt2h.jpg
Changing Spark Plugs
Remove/Install Ignition Coils
http://i33.tinypic.com/2illdtw.jpg
http://i33.tinypic.com/2ihxfmg.jpg
Replace Spark Plug
http://i35.tinypic.com/2mevbpg.jpg
http://i38.tinypic.com/2pzxv15.jpg
Remove/Install Starter
http://i34.tinypic.com/6xyu61.jpg
http://i35.tinypic.com/2uptl61.jpg
Remove/Install Alternator
http://i38.tinypic.com/e04mkx.jpg
http://i34.tinypic.com/21c9ova.jpg
Changing Oil
Instructions
http://i33.tinypic.com/dov1u8.jpg
http://i33.tinypic.com/2w3vt4x.jpg
Replace Filter
http://i37.tinypic.com/10x56dx.jpg
Suctioning Oil
http://i34.tinypic.com/4jked.jpg
Reset Service Indicator
http://i35.tinypic.com/2w536nd.jpg
Jacking up Car
http://i38.tinypic.com/bg2rft.jpg
Removing Bottom Compartment
http://i37.tinypic.com/29bhfmw.jpg
(Didn't see a how to on removing drain plug-just remove it if you really want to)
Remove/Install Radiator
http://i38.tinypic.com/30iayxu.jpg
http://i37.tinypic.com/a48zgl.jpg
Remove/Install Electric Fan
http://i35.tinypic.com/2mfy8gy.jpg
http://i36.tinypic.com/2430qbd.jpg
http://i38.tinypic.com/2d8kr4z.jpg
http://i38.tinypic.com/24fbtax.jpg
Replace Fuel Filter
http://i33.tinypic.com/2m4vl2e.jpg
Remove/Install Fuel Pump
http://i37.tinypic.com/33c3eqe.jpg
http://i35.tinypic.com/rv9ijr.jpg
More to come..........
I Also Take Requests
jmckay333 (09-28-2018)
Old 10-03-2009, 05:44 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
You're a valuable member, Karo. Much appreciated, even if I never use it.
Old 10-03-2009, 09:36 AM
omg its nate's Avatar
06 C230 6 Speed FTW
WOW Thanks!
Old 10-03-2009, 10:00 AM
Super Moderator
johnand's Avatar
2007 C230SS; 2014 ML350 BT
Looks like someone got their hands on the STAR Service Manual DVD Just got mine on Thursday. It is great, isn't it?
Old 10-03-2009, 10:44 AM
Murtu's Avatar
Hi Haro, Thanks for the interesting threads they are really helpful. I have a W203 and changed the batteries in my key/remote and since then the odometer is reading 999999 km for the total km reading. It does not roll over to 0. The trip meter works fine and records the distane travekled correctly. Km to next service does not decrease either. Any suggestions please.
Old 10-04-2009, 05:32 AM
W203E35's Avatar
2006 C350 Sport 6MT
I might not get extended warranty because of this software. Common problems/customer complaints (learn the inside secrets).
Old 10-04-2009, 11:02 AM
Super Moderator
johnand's Avatar
Next time your in there see if you find anything on generic OBD2 scan tool code P0012. I couldn't find anything on that code
Old 10-05-2009, 12:57 AM
W203E35's Avatar
2006 C350 Sport 6MT
P0012 "A" Camshaft Position - Timing Over-Retarded
I'll try to find something. Are you getting this code?
Old 10-05-2009, 01:12 AM
W203E35's Avatar
2006 C350 Sport 6MT
Here is what I found on the camshaft ("Check Basic Position of CamShaft")
http://i35.tinypic.com/29fazcy.jpg
http://i35.tinypic.com/17efxs.jpg
There is way more (Taking out camshaft, Set basic position of camshaft)
It's under "engine timing"-"Camshaft, Camshaft adjustment"
Here are possible causes:
Cam timing improperly set.
Continuous oil flow to the VCT piston chamber.
VCT solenoid valve stuck open.
Camshaft advance mechanism binding (VCT unit).
Old 10-05-2009, 06:09 AM
W203E35's Avatar
2006 C350 Sport 6MT
Did you get this resolved? A lot of people say it's because of your cluster? Did you change your cluster?
Take a look at this. Hopefully you can find someone who has something like this.
http://www.youtube.com/watch?v=jI_kE9It9R4
It's called the EnigmaTool. Find someone with it because it costs 9,500 Euro
http://www.cardiag.eu/enigma-tool/
Old 10-05-2009, 07:44 AM
advans's Avatar
C55 ///AMG, 535xi
Karo FTW
Old 10-05-2009, 12:16 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
nice!
Old 10-05-2009, 12:49 PM
oo3
oo3's Avatar
Silver 2005 C230k
wow thanks. some very informative info here.
Old 10-05-2009, 03:53 PM
benzito911's Avatar
2005 W203 SS
ye-eeeiiya! thanks
Old 10-05-2009, 04:40 PM
W203E35's Avatar
2006 C350 Sport 6MT
I take requests guys, so please if you ever need any diagrams PM me and 'll try to find what I can
Not everyone has the M272 so just let me know.
MJ, once I get home bro i'll take care of that
Old 10-11-2009, 02:17 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Old 10-12-2009, 09:17 PM
jogger's Avatar
07 c230SS
sticky!!!!!!!!!
Old 03-23-2010, 03:21 AM
W203E35's Avatar
2006 C350 Sport 6MT
Bump for the new guys
Old 03-23-2010, 05:20 AM
iJimpanzee's Avatar
2009 SLK 55 AMG
This is amazing. +1
I was just thinking.. the best DIY's ever--would be if someone listed all the things that different services require. Then compiled it into clickable sections or simply a list of things to check off.
Does anyone get what I'm kind of saying?
Rather than taking in the car to do these services, why not do them yourself at a fraction of the cost?
The thing that stops most people (or just me) is that they don't know where to start, so a compilation of a list of things in each different service would be at least one step forward into people taking the time to do things.
Once again, Karo.
*I would help compile the list if I knew what each service entailed fully..
Old 03-23-2010, 05:23 AM
W203E35's Avatar
2006 C350 Sport 6MT
There is this if it help?
https://mbworld.org/forums/c-class-w...ance-info.html
Old 03-23-2010, 09:27 AM
JLD2k3's Avatar
2002 C320
How about instructions for a rear mount turbo???
Old 03-23-2010, 11:05 AM
03MBC320's Avatar
2003 C320 4Matic
wow great post karo, wish there was one of these for a M112!
Old 03-23-2010, 05:27 PM
W203E35's Avatar
2006 C350 Sport 6MT
I still really haven't ditched the idea. I have been talking to some G35/350Z guys and have learned that it all comes down to the work is not worth it. By that I mean you are already going to do a turbo setup and spend a good chunk of money you might as well go the whole nine yards. I can't go the whole nine yards because I haven't heard of any reputable shops that can make lower compression pistons. With the stock compression which is 10.7 max I can run is 7-8psi and this is pushing it. Realistically I will probably do 4-5 to be on the safe side on the stock motor. With that much psi I probably will spend a lot of money and end up making probably 280 - 300 to the rear wheels. All this will most likely cost anywhere between 5-8k depending on the hardware (quality not ebay crap) and will need someone to specially tune the car. Atleast this is what I have been told by a lot of guys. The G35/350Z motor is easier because people have explored it. There are tons of aftermarket ECUs, and tons of info and tons of products. With the M272 no one has really explored it's capability. Again I haven't thrown out the idea 100% yet. Once i get back on track and start saving fund I'll still consider it. As of right now i'm 20% let's do it and 80% forget it.
We'll see
I'll make one for all the w203 soon. Just got to dedicate some time
Old 03-23-2010, 05:57 PM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
I know it's off topic, but it goes with the rear-mount talk... How much harder/more expensive is it to dyno tune one of our cars compared to, say, a Nissan?
Old 03-23-2010, 06:08 PM
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Karo, thanks so much for the contribution. Your thread has now been added to the OEM/Aftermarket modification stickies!
Quick Reply: M272 Do It Yourself
