Gas Mistake
And theres of course the age old story of people seeing gas delivery trucks dumping the same fuel from the same tap in the truck into all three reservoirs in gas stations.....
and of course the same truck delivering to say shell and to "beaver gas" who sell gas at significantly different prices...
I would love to be able to follow a gas delivery truck someday and see if he delivers to different gas stations...but kinda hard to spend a day hangin out outside a gas station waiting for the damn truck to show up...
Super Moderator
Bottled octane boosters are a total waste of time - I've covered this before.
Octane levels are segregated on the delivery truck. Companies run a borrow/loan system so you will often see one filling anothers stations.
Proprietary additives like Techron are added along the supply chain so they only get into Chevron, Texaco or Caltex fuel as an example. They are expensive treatments & will not be given to the opposition.
2002 Mercedes Benz C230 Coupe
Ive seen trucks fill up all storage tanks at gas stations from the same tap on the truck! Maybe the truck has the capability to route fuel from different storage tanks through the same tap...but highly doubt it.
#32
So youre saying that fuel of different octane levels are transported seperately...stored in seperate tanks and proprietary additives (such as Nitrogen enriched Shell gas) are then added directly into the gas station storage tanks?
#33
Wasn't an argument....just a clarification.
Thats good news...good to know that gas companies aren't ripping us off by selling the same gas at higher prices.
#34
Super Moderator
Glyn M Ruck probably knows the truth but would have to kill us all if he told us
this is why you use reputable gas stations and not mom and pops gas and go or gas stations at grocery stores. i would use them in my pickup or something but not a Mercedes remember you got to pay to play
Glyn M Ruck sounds shady so lets all go to shell i think he worked for chevron
sorry Glyn i had a long day so i need to have some fun you know we all love you btw which oil company did you work for i can't remember if it was Chevron or another one?
#35
2003 C230K Coupe Orion Blue
I think it depends on the city. In Vancouver there are only 1 or 2 refineries for the whole city, and my understanding is that ALL gas comes from there. Sure there might be additives put in here and there depending on the brand which may do whatever's advertised (and I don't doubt that), but personally I think the whole "fuel quality" issue is BS, ie not having them is not going to cause your engine to blow up. I've run my car HARD (ie 5000rpm, full load, ripping through mountains with the boys) on 87 for hours once as an experiment, and I can't even say the car felt any slower. These days I use 90 in my car.
Been filling up pretty much EXCLUSIVELY at a non-namebrand place (same station) for 6 years and counting now, with 0 problems. Unless you're saying bad gas caused my steering wheel buttons to crack and my door IR sensor to fail.
#36
Super Moderator
oh i am not saying that the gas at a name brand place is better just saying that hopefully it will not have water in it or wrong octane or other problems i have seem in my area at least at some independent places. + the chains in my area are usually way cleaner and safer looking. but if you live in a town with a refinery then i am sure almost all your gas comes from their.
#37
Super Moderator
#38
Super Moderator
Local stations are usually supplied by local refineries - Moms & Pops do not see the QC demanded by the majors.
I see what you mean Sam
#40
Super Moderator
#41
Super Moderator
#42
Super Moderator
Yes - loved the many years of international experience. Oil companies are dinosaurs & some of the very senior management should be extinct. I think this applies to many large Corporations. But they were good to me. Caltex was a very entrepreneurial company blazing new trails across Asia etc. Once we merged things became far more conservative with mature market attitudes & risk aversion.
#43
For Crisake....how many threads do we have on gasoline and octane?
What does it say inside the fuel door?
What does it say in the manual?
It says, use 91 octane MINIMUM.
I ran 87 octane once for about 50 miles, my car felt like it was missing a cylinder.
I sure as hell did not fill the tank.
The manual states it's ok for emergencies but to go easy on the throttle.
If I accidentally FILLED the tank, me; I''d siphon off to another car as much as possible and then fill up with 91. My car barely runs on 87.
I used to argue that the top tier gases were a scam too, but while the octane ratings may be the same, they don't run the same. But it became so very obvious....
I get a noticeable boost from Shell, 76, and Chevron premium.
I tend to prefer Shell. I seem to get the most oooomph from their gas.
Of course, keep in mind my engine is modded, and not just a pulley.
See my sig.
See my sig.
#44
Splinter - my M271 doesn't mind 87 octane either. I can't tell a difference in performance or fuel economy. I use 93 almost exclusively but after so many of these threads I decided to just see what the big deal was about. I couldn't tell any difference whatsoever.
#45
2005 C 230 Kompressor
The big deal about octane is denotation. I only run the recommened octane in mine. The higher the octane, the slower the burn rate is for the fuel, translation ... higer octane fuel can stand higher compression ratios or power adders (turbos/superchargers). More compression or power adders = higher cylinder pressure which = heat. Too much heat in the cumbustion chamber may ignite the fuel even without a spark. If your fuel ignites prematurely then it attempts to send the crank in the wrong direction while the pistion is coming up. For instance, if you have your ignition timing set at 23 degees before Top Dead Center without nitrous then you need to set it significantly lower when on the juice because the nitrous makes the fuel burn faster. The plug is always lit before the piston reaches TDC to start the combustion cycle.
#46
Super Moderator
https://mbworld.org/forums/c-class-w...er.html:smash:
