To those who've opened headlights: should I use more "glue"?
Old Oct 24, 2009 | 07:15 AM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I opened up my CLK BiX headlights so I could get the shrouds painted to match the car, and I'm wondering if I should add any more glue when I go back together with the lens. This is the first time I've ever opened up headlights and I want to be sure they won't leak and get moisture inside.
Old Oct 24, 2009 | 10:18 AM
samaritrey's Avatar
Super Moderator
THE C350
it is not glue
i have read in one of the ignitor replacement diys to get headlight sealant from Nissan
Old Oct 24, 2009 | 10:24 AM
HellsAngel's Avatar
03 c320 coupe
advans opened his clk headlights last week, wait for his answer
Old Oct 25, 2009 | 03:49 AM
phucmang's Avatar
05 c230k
super glue!!!
Old Oct 25, 2009 | 06:03 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
its rubber butyl, nissan sells a roll for $20. Its the same stuff all the oem manufacturers use.
Oh yeah, make sure you use the automotive rubber butyl such as the nissan sealant. DO NOT USE the ones for your home windows, that variant can't take the heat that headlights produce.
If you dont want to pay $20, you can also use silicone.
Here's the link
http://www.mynismo.com/products/?id=5577&rsku=0
Old Oct 25, 2009 | 09:15 AM
91RS's Avatar
Alright, that's what I need. Do you think it'll be necessary to add more?
Old Oct 25, 2009 | 09:59 AM
TemjinX2's Avatar
not if you open it carefully. you can add a layer of clear silicone if your really worried.
Old Oct 25, 2009 | 10:11 AM
91RS's Avatar
Alright, I think I was pretty careful. I'll take a look at them later and make an executive decision. I'm pretty sure I got all the cracks from the broken tabs filled in, so they should be air tight.
Old Oct 25, 2009 | 10:13 AM
WaveyKat's Avatar
Something Slow
i add a layer of Gray Silcone when i opened mines! just make sure you seal it real good! dont want moisture to get in there!
Old Oct 25, 2009 | 10:21 AM
91RS's Avatar
Maybe I'll just do that then, I have plenty of gray GM engine sealant.
