i need your help. - urgent
C180 Kompressor Saloon
hi guy
i am in the process of buying some wheels and i need to know if they will fit.
they are bbs lm reps off a vw golf mk5. i know the stud patetrn is the same and they are offset 45 but i know there are spacers avaliable
what i need to know is do i need to take into account any other factors,
heres the link
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
help is urgent please cos i wana buy them now
thanks in advance
heres the link
thanks in advance
a quarter mile at a time
ask the dealer about centerbore size. MB should be 66.56 Otherwise, you'll probably need a 10mm spacer. If you have the large fixed piston brake calpers, there may be clearance problems as well. Hope this helps.
will i have a problem with the centre bore size. the golf mk5 has a bore size of 57.1, if it is a problem then how can i sort this out coz its a really good deal @ £700
i dont have the larger brakes
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
VW/Audi bolt spacing is also 5X112 but the offset & bore are wrong. I do not recommend you go this route. Too many problems. You can't get decent hubcentric spacers to fit so you will likely suffer vibration & not be able to do anything about it. Benz centre caps won't fit either.
Nothing is impossible - this is not wise.
