anti theft system problem
Old Nov 1, 2009 | 04:14 AM
jerryml430's Avatar
2006 c230
Exclamation anti theft system problem
hi all,
ok so i'm having a problem with the anti theft system on my 06 c230. Whenever i use the panic button or try to test the alarm the lights will flash without a sound. I guess it the serin horn so i'm wondering if you guys know where is it located on the 06 and is it easy to be replaced and if you guys know any cheap pleace to get, i think dealer will ask for too much $ for it
Old Nov 1, 2009 | 11:54 AM
Glyn M Ruck's Avatar
Super Moderator
The siren is in the RHS front wheel well behind the wheelarch shroud.
Old Nov 1, 2009 | 12:00 PM
krisv420's Avatar
02 C320 Sedan
Its not like the junkie Mercedes anti theft system works that great... Got my windows smashed and the alarm didn't even wake me up.. When my car was sitting 20 feet from my window..
Some car alarms work great.. You can jump on the back of ppls bumpers and it will set it off.. Mine i can have sex in the back seats and nothing will happen until i unlock the doors haha..
To sum it up Mercedes your stock anti theft system sucks**
Old Nov 1, 2009 | 01:21 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by krisv420
... Mine i can have sex in the back sets and nothing will happen until i unlock the doors haha.....*
It doesn't go off unless you're with someone
Old Nov 1, 2009 | 04:57 PM
acr2001's Avatar
2012 C300 4Matic
...he was asking for a comment like that
Old Nov 1, 2009 | 05:10 PM
Super Moderator
Old Nov 1, 2009 | 05:33 PM
samaritrey's Avatar
Super Moderator
THE C350
Old Nov 1, 2009 | 11:33 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
-- correct.. Alarm sounds when car is jacked up, not when driver is jacked... off.
My tow-away sensor works fine. I had the car locked last time I had a tire problem and it sounded when the jack lifted it a bit.
Old Nov 2, 2009 | 06:40 PM
acr2001's Avatar
2012 C300 4Matic
I did the same thing. Those with an 07 (in the US anyway) don't have that sensor anymore.
Old Nov 6, 2009 | 12:02 AM
jerryml430's Avatar
2006 c230
ok guys lets get back to the subject, so i took the car to the shop and they couldnt find any code or any reasons why the lights flash with no sounds so i ask some guy and he said sometimes it a programming thing and i should go to the dealer and i have noticed one more thing when i keep on pressing the unlocking button the windows will roll down but when i keep pressing the locking button they won't go up. so what do you think guys
Old Nov 6, 2009 | 12:22 AM
mleskovar's Avatar
'17 Jaguar XF
Let's try this again in a couple of hours without the meth.
Old Nov 6, 2009 | 12:37 AM
acr2001's Avatar
2012 C300 4Matic
THIS.
Your siren unit / module (whatever the hell it's called) most likely needs to be replaced.
The window problem is most likely related to your meth addiction.
Old Nov 6, 2009 | 02:58 AM
jerryml430's Avatar
2006 c230
you guys are crazy but anyways i couldnt believe how easy was it to get the alram to work back. i was checking the fuses about an hour ago and once i pulled that fuse out and put it back in the sound went crazy. eazy fix back in business and i'll check the thing about the window next week, it's not something that i really care about
Old Nov 6, 2009 | 02:10 PM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Which is such bullcrap! It's a MERCEDES... don't skimp on us!
Old Nov 7, 2009 | 02:13 PM
LILBENZ230's Avatar
The 07s have a lot of little cost saving things that the 05s didn't have. No more leather inserts, cheap little lock and unlock tabs, all the headlight panels are black regardless of interior color, etc.
Old Nov 8, 2009 | 02:11 AM
acr2001's Avatar
2012 C300 4Matic
Also:
No more cellular antenna. No more pre-wiring for phone system or satellite radio or aux input. No more upper compartment in the center console. Cheaper looking fog lights on the luxury version (no idea about the sport). No more oil level measurement or oil quality monitoring. Those are the items I know of, there are probably more.
Old Nov 8, 2009 | 06:39 AM
LILBENZ230's Avatar
The Sport retains the same fascia and fogs from 2005 to 2007. I forgot about the oil level monitoring. That's a biggie.
Old Nov 8, 2009 | 01:23 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
It went off one time and I actually heard it. The sound is quite annoying.
Old Nov 8, 2009 | 11:28 PM
bdgdl08's Avatar
Wait, it doesn't monitor at all, or just doesn't give you an oil level like the earlier models. Even my CLK told me when my oil was too low.
Old Nov 9, 2009 | 01:35 AM
acr2001's Avatar
2012 C300 4Matic
As I understand it from comments I've read on this forum, the 07 system will still alert you about low oil. I'm not sure if that alert comes up when you are simply low a quart like the old system, or after you've gone dangerously low.
Would a low oil alert be triggered if you turn your key to run (without starting the engine!!!) as you drain the oil during a change? That might be one way to find out.
