Weird Screw to Remove Left Side Mirror
Old Nov 1, 2009 | 08:26 PM
SkankZ's Avatar
2006 C230 SS
Sadly.. my car was involve in a "hit and run" last night and smash into my driver side mirror.. it turn 180 degrees causing damage inside the mirror. the mirror itself is broken but luckily the cover is okay. i'm trying to take off the whole mirror but not sure how can i take off this screw
the first picture is the actual screw but it have only 5 point star and the right is a screw that is similar but 6 point.
here is the damage.. it will be helpful i can have your opinion what i should do.
Thanks!
Old Nov 1, 2009 | 08:28 PM
samaritrey's Avatar
Super Moderator
THE C350
that is a torx
Old Nov 1, 2009 | 09:00 PM
SkankZ's Avatar
2006 C230 SS
when i look up "torx" it look the same but the screw have a nipple in the middle. does it make a difference?
Old Nov 1, 2009 | 09:04 PM
e1000's Avatar
a quarter mile at a time
specifically it's a "security torx" screw
samaritrey's Avatar
Super Moderator
THE C350
no clue but i think it is a special type of torx. search for power mirror install or something like that i am sure they will tell you what type of driver is needed to remove it.
Old Nov 1, 2009 | 10:34 PM
Moviela's Avatar
The screws that hold the morror assembly to the door are standard Torx screws that have a "washer head" and are gold alodine color. There is only one photo in your post, and it shows a black security Torx screw. Perhaps your car was serviced by a careless mechanic who used any screw handy to fix your car?
Old Nov 1, 2009 | 11:26 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You need to get the security torx bits to remove th screws. They are like that to prevent thef of the mirror.
Old Nov 2, 2009 | 12:51 PM
SkankZ's Avatar
2006 C230 SS
thanks for all your replies guys time to go find a replacement mirror
Old Nov 2, 2009 | 08:29 PM
seagel1000's Avatar
05 C230 Kompressor
Dang, looks like you did a photo shoot just for the screw. Talk about a Macro shot!
Old Nov 2, 2009 | 09:49 PM
moparrbust's Avatar
2005 Crossfire SRT-6
M-B used to use standard T20 torx screws for the mirrors for years...........then they switched to the special tamperproof 6 point torx(probably because of all the a-holes stealing M-B mirrors for their Honduhs)..........and now they have switched back to standard torx screws. You can buy the M-B "special tool" torx bit from the dealer for about $12 retail.
Old Nov 2, 2009 | 10:35 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by moparrbust
.. You can buy the M-B "special tool" torx bit from the dealer for about $12 retail.
You can get a 100 piece collection of different security/torx/hex/etc tips for $8 from Harbor Freight tools. 91310-0VGA
Old Nov 3, 2009 | 01:25 AM
krisv420's Avatar
02 C320 Sedan
Looks like it didn't help the other kat on here
Old Aug 11, 2010 | 10:47 AM
CarLK500's Avatar
SLK230 '98 CLK500 '06
aint much of a security screw if you can just buy a bit is it?
Old Aug 11, 2010 | 11:19 AM
iJimpanzee's Avatar
2009 SLK 55 AMG
Do you happen to know the part number for just the lens part of the side view mirrors?
I'm talking about the plasticy part in the front of the side-view mirrors, and not the mirror itself.
Mine is cracked on the drivers side, and I'd like to have it replaced before I have it tinted
Old Aug 11, 2010 | 04:15 PM
Gynecologist MD's Avatar
Hopefully another MB soon..
What are the tools called to remove the "opposite" of these?
When I open my drivers door, theres 2 screws that holds one of the hinges and it looks like its "inside out" compared to this one.
Just curious, thanks!
Old Aug 11, 2010 | 06:53 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Security Torx bits will remove these screws. Harbor Freight sells the set for around $7.
Or, you can carefully drill out nipple at the center. Once that is removed, then you can just use the regular Torx bit.
Old Aug 12, 2010 | 05:10 AM
iJimpanzee's Avatar
2009 SLK 55 AMG
I thought a regular 12mm wrench works on holding/removing them?
I believe they're called "inverted torx" screws/nuts.
Or at least that's what I read from the Sway-Bar DIY thread
Old Aug 12, 2010 | 09:21 PM
Glyn M Ruck's Avatar
Super Moderator
Centre hole "security" torx drivers are readily available.
