Maximum size spacers
Old Nov 7, 2009 | 07:13 AM
HellsAngel's Avatar
03 c320 coupe
Well i am running a non staggered setup : 18x8... & i think, as most of you will agree, spacers are a must... however before ordering i was wondering whats the maximum size spacers i can buy... (i am probably ordering from ebay.de since i am in europe now)...
check below pictures :
thanks..
Old Nov 7, 2009 | 07:15 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i'm running 15mm and 12mm hubcentric spacers without any problems. But there on 19 x 8.5 wheel.
Old Nov 7, 2009 | 07:16 AM
HellsAngel's Avatar
03 c320 coupe
i was thinking 30mm in the back... (of course hubcentric, i'm going H&R or Eibach).....
Old Nov 7, 2009 | 07:23 AM
TemjinX2's Avatar
i think frankw is the best person to ask.
Old Nov 7, 2009 | 07:24 AM
HellsAngel's Avatar
03 c320 coupe
i know, & i am waiting
Old Nov 7, 2009 | 08:45 AM
ciacia's Avatar
C240 W203
What are the offset of the wheels? I'm not sure if coupe's offset is the same as sedan's W203, but i think the maximum offset for unmodified fenders (for sedan) should be +30, this should count for normal W203 as well as AMG.
i think running 30mm spacer would not be safe, you would have to use extra long bolts as well. Normally 15mm would be sufficient and most producers would only recommend that width at the max. I myself have used 20mm (hubcentric) at the front and rear. While driving on highways (hi speed), there were no problem with shuddering at all, but it affected the handling so much that it made the car understeer a lot. I would recommend staying below 20mm.
At the moment i am using 8mm spacer at the back to have the rear wheel sits flush to the fender, currently the effective ET is +29 (normal ET is +37). Like below...
Old Nov 7, 2009 | 08:55 AM
HellsAngel's Avatar
03 c320 coupe
the offset of my wheels is 35mm...
15mm spacers will push the wheels 15mm on each side ? on 15mm in total ?
maybe you understeered because of your 20mm FRONT spacers ?
Old Nov 7, 2009 | 09:23 AM
ciacia's Avatar
C240 W203
15mm spacers will push the wheels outwards (on each side), therefore your effective ET is +20. On W203 sedan, that kind of offset will push the wheels to sit out from the standard fenders. Mind you though, i found that the right side offset is less than the left side offset on the W203 sedan.
And yes i did understeer a lot when i used the 20mm spacers on the front.
Old Nov 7, 2009 | 06:03 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
there is no right or wrong answer for spacers. anything larger than 15mm spacer they are designed to bolt onto the hub first and then use the lug nuts instead of the lug bolts.
as for how thick do you want to use. that's up to how you want it to look. 15mm for your rear would be decent.
Old Nov 7, 2009 | 06:05 PM
HellsAngel's Avatar
03 c320 coupe
excuse my newbie"ness" in wheels setups, but 15mm wouldnt give me any rubbing or whatever issue ? do i need longer bolts ?
thank you
Old Nov 24, 2009 | 03:03 AM
HellsAngel's Avatar
03 c320 coupe
i found h&r 10mm spacers but it says that they are not hubcentric.. is that ok ?
"Total Track Widening 20mm (10mm Each Side) Flat Spacers (Not Hubcentric)"
Old Nov 24, 2009 | 07:52 AM
TemjinX2's Avatar
do not buy non hubcentric spacers unless you like having wheel vibrations when you drive.
10mm hubcentric spacer
http://cgi.ebay.com/ebaymotors/Wheel...ht_1490wt_1086
Old Nov 24, 2009 | 08:02 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Hmm - my 20 mm H&Rs did not do as you indicated, and I never had a problem with them.
The 20s I had were for my stock 17's - haven't had spacers on my summer rims yet - they are 18x8 like yours, so I'm interested in your results. But I'd guess that 12-15 would probably be best.
Old Nov 24, 2009 | 11:41 AM
HellsAngel's Avatar
03 c320 coupe
thanks for the link but i'd rather order from europe... + id like to stick with H&R / Eibach....
well im having troube finding 15mm H&R, its 10 or 20.. and the vendors that sell the 15mm spacers are asking too much...
i will keep you updated if i find 15mm H&R's in europe for a decent price...
Old Nov 24, 2009 | 12:41 PM
tommy's Avatar
OK, good luck. Looking forward to seeing what you end up with.
Old Nov 24, 2009 | 06:27 PM
LinDenKid's Avatar
C230 coupe 2002
, you see the way your grill shines? , stop being cheap and take it to a body shop(say no to spray paint) lol.
Old Nov 25, 2009 | 01:33 AM
HellsAngel's Avatar
03 c320 coupe
of course it will shine, it has the sun in its face ????
Old Jun 29, 2010 | 05:40 PM
HellsAngel's Avatar
03 c320 coupe
i ordered 15mm hucentric spacers for the rear yesterday, i'll post pictures as soon as i reiceve and install !
Old Jun 29, 2010 | 07:05 PM
tommy's Avatar
looking forward to the results.
do you have wider tires on the rear?
Old Jun 30, 2010 | 01:16 AM
HellsAngel's Avatar
03 c320 coupe
no i was a noob at the moment
