Hardwire Radar Detector install question
The only fuses i have are ones that came with the add a curcuit. and it did not come with "2" 5 amp fuses. If i was to use a 3 amp fuse to the slot with the wire to it and a 5 amp to the slot with no wire, will that effect the performance of the radar at all? or will it be to weak? and will it be safe?
Also, I just have a 3amp fuse in the slot with the wire, is that ok?
Thanks guys!
Thanks guys!
Wow! i remember this thread! :p
Yes, i left it at that setup, it was perfect. I even left the same setup and swaped it into my C55. I never used a 2amp fuse. Just the 5 and 3. If you mean that you need only 1 fuse, well accrding to what everyone else told me, you need 2.
