DDM Tuning HID's $30!
THANKS!!
im not sure what bulb type for a 2006 c230? and are stock factory xenons 6000k?
Thanks!
Your foglight are 9006
Stock is 4300K
I wouldn't get anything over 6000K. It becomes too blue and cops stop you. If you have nothing to worry about then 8K
Below 4300 is yellower
4300 is white
6000 is light blue (slightly blue)
8000 is Blue
above that becomes darker more into purple.
Almost forgot there is 35w and 55w.
55w is more brighter than 35w.
I use 35w and I live in the city so it's good enough for me. But if you live around the suburbs or anywhere that there aren't a lot of traffic/lamp posts then I would go 55w
EDIT: So, I know that this would pretty much be complete overkill, but I was wondering if anybody had tried the 55w for fogs. I know that the site says that it is not recommended because of the heat involved, but I am curious if it is doable.
I have OEM Bi-Xenon's with OEM 4300K bulbs. I have 6000K HID's in my fog lights. My foglights look much bluer than my Bi-Xenon's. However if you are adding an aftermarket Xenon kit to your factory halogen headlights, then 6000K HID headlights should match perfectly with 6000K HID fog lights.
Thanks.
Stock is 4300K
4300 is white
8000 is Blue
That's a video of my C230 running 55w 6000k HIDs. The camera simply couldn't capture it any better. This does them no justice.
they seem to be aimed a bit low
but then again, aiming the halogens higher would totally blind oncoming traffic
Looks Good
I was driving and the "left fog light out" light comes on.....like 5 seconds later I hear something. I pretty much instantly knew what happened. I pull over and see my ballast on the ground connected to the bulb via 2 wires BUT the OEM plug is not there......I later found it on the ground yanked out of where ever it goes. So now I can't re-connect it, or even put in a regular fog light. I guess I have to go to a mechanic now.........
idk why it fell off. I attached it w/ the HD 2 Sided tape...it was really sticky. The other 3 are all fine too
I know dude....Im pissed
Well it was on the crash bar.....and just fell I guess. There is that plastic pan at the bottom of the engine bay, but I guess it missed that lol.
The OEM wire like split in 2, so I think I can re-attach it
gonna try after work.........
*edit: I did it!!! I put the wire back together and wrapped it in electrical tape....and it works. I put the ballast back on the crash bar, but I used better tape and zip ties from the top so it can't fall.
So......all 4 lights working perfectly, no error messages
My HID kit came today! It took me quite a while, but after a trip to the hardware store (well, two of them) to get a unibit do drill holes in the dust covers, I got them installed. I had to use the error eliminators, though; I installed without them, which worked until I turned on the car, then flickering and bulb out error. I went for a test drive, re-aimed my headlights a bit, and now everything is great. I had trouble figuring out where to place the ballasts. I need to be able to drive the car, so I used the adhesive (for now), but used the small zip ties that came with the kit so that, if the adhesive fails before I can fix their placement, they will keep the ballasts around. If the adhesive fails, the ballasts will be hanging from tubing.
