Steering is making a popping noise
Old Nov 28, 2009 | 04:55 PM
zcurtis00's Avatar
c320 4matic
Whenever I turn the wheel to the left it makes this like popping noise. I was wondering if anyone else would know what could cause this.
Old Nov 28, 2009 | 11:32 PM
snail45's Avatar
E55 AMG
That sometimes happens when your spring is not seated correctly.
Old Nov 29, 2009 | 01:28 AM
Glyn M Ruck's Avatar
Super Moderator
Check sway bushes and links for play - caster bushes for cracks - rack bolts for tightness. Unfortunately this is sometimes the rack itself (likely internal bushing). On Johnands car it required a rack replacement. Get under the car & listen while someone turns the steering & listen. (obviously make sure that PS fluid is topped off correctly - although low fluid causes a shreaking noise at full lock)
Old Nov 29, 2009 | 02:01 AM
Super Moderator
See Johnands thread from post No 128 - unfortunately there is a big chunk missing that we did via PM to diagnose.
https://mbworld.org/forums/c-class-w...+popping+noise
Old Nov 29, 2009 | 05:04 AM
zcurtis00's Avatar
c320 4matic
Thanks guys, I'll try and get under it tomorrow and see. Also, when my foots on the gas pedal I can feel the pop too.
Old Dec 10, 2009 | 04:34 PM
govertime's Avatar
I was getting a distinct popping noise when my sway bar linkage (might be called tie rods) broke. Basically this rod/linkage connects the front sway/stabilizer bar to the strut (or hub???) if i remember correctly. Anyway, get under your car and grab a hold of the different rods/bars/linkages and give 'em a good tug to see if they make a popping noise. Mine was really obvious. The linkage has a ball/socket which allows movement and unfortunately the socket part is cheap plastic that easily wears out/breaks. Its a pretty cheap and easy job to fix.
Sorry, I can't load MB's EPC right now so I'm unable to give you the MB verbiage and part number.
Also, as Glyn M Ruck said, it could very well be a bad castor or other bushing or even less likely a steering rack issue. Personally, I'd start with the linkage/tie rod cause the ball part of the rod going in and out of a bad socket really does make a distinct popping noise.
Good luck.
