water leak in the cab
Old Nov 29, 2009 | 05:42 PM
scotsimba's Avatar
Mercedes C class
Unhappy water leak in the cab
hi there, discovered a water leak on drivers side and water dripping from hood release catch handle. Got a mechanic friend to investigate the leak and he stated the grommet and the outer plastic was dry inside the cab, however the cable inside sheath was wet.
Please help as how easy is to replace the hood release cable for c-class merc 220cdi.
Thanking you in advance.
Old Nov 29, 2009 | 07:57 PM
Glyn M Ruck's Avatar
Super Moderator
That's a weird one. Check the cable at the front latch where it comes out of the sheath & apply a liberal blob of grease to act as a seal.
Most common leaks in drivers & passenger footwells is a blocked aircon housing drain.
Old Dec 2, 2009 | 04:46 AM
scotsimba's Avatar
Mercedes C class
Thanks. I'ill do that. See if the water stops driping into the cab. The aircon is ok. The cable runs next to the fuse box.
Old Dec 2, 2009 | 05:13 AM
Super Moderator
Yeah - the aircon is simple to check. As long as you are leaving a trail of water under the car with the aircon running - the drain tube is open.
