Catalyc Converter - Need Straight Answer
05 C230K SS and 02 C240
Hi,
I was told to replace the catalytic converter on my 05 C230K and I'm not going to replace it with the OEM because they just ridiculous expensive. I'm thinking of replacing it with any hi flow catalytic converter that can pass SMOG check and may result in a better performance.
Since I do not live in CA, what kind of after market converter can I use or you guys use?
Thank you.
Thank you.
15 MB Sprinter, 14 MB S550, 08 Smart Fortwo, 04 Dodge Sprinter, 87 MB 190E 2.3-16
All the aftermarket cats I have encountered are not mandrel bent like the OE.
My suggestion would be to purchase comparable sized Stainless Steel Magnaflows and have a meticulous exhaust fabrication shop cut off old and TIG weld new cat in place while retaining as much of the OE piping possible.
I've got a Magnaflow on my car; the P0420 error does pop up every so often; so far, I just clear it with my Scangauge II.
There's a fix that's spotty on it actually working; I haven't tried anything yet.
From front to back:
Green filter
Supersprint Header, hotcoated to reduce engine bay temps
Magnaflow cat
Eisenmann Race exhaust
Scarily loud; i'm going to have to look into doing something with the resonator to reduce the drone
Green filter
Magnaflow cat
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
![action](https://mbworld.org/forums/images/smilies/action1.gif)
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
03 g35 coupe...........02 c32 Sold
ok i double checked. I was right, federal law saids all new cars after 1995 have emissions warranty on the cat for 8yrs or 80,000 miles. Just take to the mercedes dealership and have them fix it under warranty.
here's the print out from the epa.
http://www.epa.gov/oms/consumer/warr95fs.txt
As far as sound clip, I'll get to that when I do my siggy in the spring, assuming I remember.
You bet! Good memory! Here's the link:
https://mbworld.org/forums/c-class-w...n-ticking.html
Close to 80K?!? Yeah right, I wish!!! My car is already at 95k. Still have another 5k under MB extended warranty but catalytic converter is not covered....go figured.
Anyway, thank you everyone for your input. You guys are awesome. It seems like magnaflow or random technology would do.
Yes, much cheaper; mine was 200-something installed for a universal; needed a bung welded on. The quote I got for an OEM one was $1350 if memory serves.
C320 coupe
