Hole through firewall in C160 w203
I am living in Norway and want to bild in some Interior heater in my car. In this case i need to have hole through firewall with at least 20 mm diameter. Is it there some existing hole, so i dont need to drill?
Best regards
Zoran
With its 120bhp 1.8-litre supercharged engine, the base model can sprint from 0-62mph in 11.4 seconds - which is 1.7 seconds slower than the C180 K.
About the hole. I have heard that there is a hole on the driver's side near the front SAM. I don't know much about it, or if the side is different based on LHD or RHD. I'd search some of the threads about woofers.
I bet a chip would do wonders in this thing....they've taken a reasonably fast engine and crippled it.
The must put a giant restriction in the intake to slow it down.....
I'm doin' 0-60 in 6 easy.
What kind of mileage do you get? (I keep saying we don't need Prius's and Smart cars to get good mileage....European carmakers already know how to get good mileage, just
don't bother to send those cars to the US.
here's a pic from my carputer thread to give you an idea. I basically ran my stereo wirings through thoses 5 holes.
Any advice?
Ed
if you take out the battery, you should see the red oem wire thats going through one of the 5 holes and you should be able to push out the corks from there.
Just wanted to confirm that these are the 5 corks you speak of.
From my car, i can see a strip of possible holes. From the bottom up it appears as theres 3 holes filled with a plastic plug with a disc backing then the two red wires take up the remaining holes making the " 5 corks". an additional 4 holes, plugged with thick rubber "corks" ensues above. What are they?
Are these all holes, just different plugs? Or are they different things?
Where do these holes lead? Can i simply pull out one of these corks and then feed wire into it freely? Again where does the wire lead.
Sorry for all the info and precise questions.
Many thanks.
W203er
Note. Image taken right behind battery on the mid right side. Thx
