Weak FM signal after installation of multimedia
Old Dec 6, 2009 | 03:58 PM
LUKA_CRO's Avatar
w203 Coupe
... i have a problem with FM signal in car...
... not so long ago I install Panasonic CQ-vw100n multimedia sistem in my car and from that moment the FM signal in car became weak...
...I know that is because the original Becker Audio sistem with CD uses 2 antennas, and now the new sistem uses just one...
... in the workshop they put me in some antenna amplifier, it's a bit better, but that is just not as nearly god as before...
... I'm interested is there any solution to this situation, some adapter, so I can use both antennas to get FM signal again with my new sistem ? ...
Old Dec 6, 2009 | 04:37 PM
WaveyKat's Avatar
Something Slow
not to be mean dude but if you search thru the Audio thread you will see the answer!
Old Dec 7, 2009 | 08:19 AM
LUKA_CRO's Avatar
w203 Coupe
... it's ok, but I allredy searched there and found nothing for 2001 c-class, there is some audio jack but only for audio 10 that is 2004+...
... i think this is that other wire that has nowhere to go in new multimedia system...
Old Dec 7, 2009 | 01:26 PM
WaveyKat's Avatar
Something Slow
look at post #943 here
https://mbworld.org/forums/c-class-w...images-38.html you need to add power to the wire
Old Dec 7, 2009 | 03:23 PM
LUKA_CRO's Avatar
w203 Coupe
... i already watch that but I can't see pictures...
... how to add power to that wire...
Old Dec 7, 2009 | 06:35 PM
WaveyKat's Avatar
Something Slow
Tap the Cigarette lighter and run the wire to Power the OEM antenna "A5 Black"! if you look at the PDF file you will see wire "A5 automatic antenna" you need to add some sort of POWER to it and your FM service will be like stock. you still have to plug in the FM jack into the radio aswell!
Old Dec 8, 2009 | 09:47 AM
LUKA_CRO's Avatar
w203 Coupe
.... thanks a lot..
Old Dec 8, 2009 | 10:24 AM
LUKA_CRO's Avatar
w203 Coupe
... and if i buy this mercedes antenna adapter could i power the black A5 wire from this orange wire...
