error codes help please
Old Dec 12, 2009 | 03:01 PM
c32used's Avatar
LET C32 2002
Question error codes help please
I have a friend with a 04 C230k and following error codes
1. p0238
2. p0620
3. p0172
Recently the o2 sensor and alternator was replaced...car has over 130k miles. Front brakes were done but it still say brakes shop warning could it be brake sensors...I doubt they were replaced.
Old Dec 12, 2009 | 03:02 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Yes you must replace the brake sensors in the pads to get rid of that warning.
Old Dec 12, 2009 | 05:35 PM
Glyn M Ruck's Avatar
Super Moderator
New sensors & cancel all codes.
Old Dec 12, 2009 | 05:54 PM
c32used's Avatar
LET C32 2002
Which ones? They already replaced the o2 so what else?
Old Dec 12, 2009 | 07:53 PM
Super Moderator
P0172 = System too Rich (Bank 1)
P0238 = Supercharger Boost Sensor A Circuit High
P0620 = Generator Control Circuit Malfunction
OK - your friend has done O2 sensors
Have they diagnosed the SC boost sensor?
You say the regulator has been replaced in the alternator
And you are still triggering brake pad sensor warnings - replace the sensors - it should have been done with the pads.
Cancel all codes with a STAR or OBDII scanner & hopefully none will return
