Camera for G Class Command
Old Mar 6, 2010 | 03:23 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
Can you post the pictures here, too? I can't see them without signing up.
Old Mar 6, 2010 | 06:50 PM
hercules's Avatar
W203 C200K-2003
This is my first installation
Cameras I used for for my experiment to get to a discrete and more appropriate to the car
Final result
First step is to modify boot handle
Camera for G Class Command-photo6.jpgCamera for G Class Command-photo7.jpgCamera for G Class Command-photo8.jpg
Old Mar 6, 2010 | 07:02 PM
hercules's Avatar
W203 C200K-2003
Here are the next
Camera for G Class Command-photo15.jpgCamera for G Class Command-photo17.jpg
Camera for G Class Command-photo29.jpgCamera for G Class Command-photo14.jpgClick image for larger version
ID:	177556Camera for G Class Command-photo18.jpg
Old Mar 6, 2010 | 07:15 PM
hercules's Avatar
W203 C200K-2003
final
Attached Thumbnails Camera for G Class Command-photo22.jpg   Camera for G Class Command-photo23.jpg   Camera for G Class Command-photo25.jpg   Camera for G Class Command-photo26.jpg   Camera for G Class Command-photonight.jpg
Old Mar 6, 2010 | 08:00 PM
91RS's Avatar
Wow, that looks very nice! I do like that. I may have to get a new license plate applique since my tag bolt holes are starting to get stripped out, so I'm definately going to keep that install in mind.
Where did you get the distance-o-meter though? Did that come with that particular camera?
Old Mar 6, 2010 | 08:24 PM
hercules's Avatar
W203 C200K-2003
No that came with the reverse sensor interface I installed in the rear bumper strip because my car did not have that from factory.
The interface is connected in line with the video signal from the camera then to the Comand NTG2.5
Old Mar 6, 2010 | 08:34 PM
  #32
91RS's Avatar
What interface did you use? I wouldn't mind having that to add to my install.
Old Mar 6, 2010 | 08:43 PM
  #33
hercules's Avatar
W203 C200K-2003
I will try to find the link tomorow and will post it
Old Mar 10, 2010 | 04:49 AM
  #34
hercules's Avatar
W203 C200K-2003
Here is the link
http://www.aliexpress.com/product-gs...olesalers.html
Old Oct 2, 2012 | 11:46 AM
  #35
hjardali's Avatar
Mercedes C230 Kompressor 2005
Good Job Mr. but how did you link the camera to your command set ? i have the same command set NTG2 and there is no socket to plug in the camera. I have one blue for GPS antenna, one yellow for FM radio and the other is black for also the radio. So where did you plug the camera?
Plus what did you use to enable the Bluetooth? is your car wired till the armrest console? is there is a plug ready for bluetooth or you also installed yourself ?
About navigation, is it possible to have a GPS antenna only without a DVD navigation map ? in the command set there is three buttons:
1- SAT
2- NAV
3- MAP
What is the difference between these three ? if i only installed the GPS antenna what will happen?
Thanks in advance for your help,
Hani
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
