Tires visibly have slight wobble when vehicle on lift in the air (@ around 15mph)
Old Jan 29, 2010 | 10:15 PM
Kar don's Avatar
Mercedes-Benz
Dealer had my car to diagnose a vibration at about 70-80mph which I thought was the glycol T/C issue. They said all 4 tires are out of round and "wobble". They put the car on the lift, put it in drive, and set the car at about 15mph and showed me that the tires "wobble". WTF, does this mean anything that a free spinning tire does this? I had one of them replaced with a brand new one 2 months ago due to a flat and this one also "wobbled". They said I need 4 new tires. Thoughts?
Car is a 2003 C320 4matic, tire is Michelin Primacy MXV4 on 16 inch OE wheels, 3 have 26k miles 1 has about 2k miles.
Old Jan 30, 2010 | 04:40 AM
Glyn M Ruck's Avatar
Super Moderator
OE 16" wheels do not usually bend. They are as tough as hell. There should be no run-out on the wheels & no run-out on the tyres. Call in Michelin for a warranty replacement. Otherwise they will have to grind them true which is not an elegant solution. I'm presuming that the tyres are correctly mounted.
Michelin should at least credit you for remaining tread. I've recently fitted new AMG wheels & new PS2's & I checked all 4 on the balancer. Zero run-out & the car is beautifully smooth at all speeds.
Old Jan 30, 2010 | 04:57 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Are all 4 wheels properly balanced? Did you recently rotate tires?
If car hasn't been driven in a while,... flat patch can occur at rubber tire. Usually round itself after its been driven. Where are you? If you're in a cold area it'll take a bit longer for tire to round out.
Old Feb 4, 2010 | 12:48 PM
Kar don's Avatar
Mercedes-Benz
Ok so had all 4 tires load forced balanced and still the noise exists. Car is driven daily.
Old Feb 4, 2010 | 01:47 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I had an issue with raodforce balancing. If not done properly, I believe <10lbs, you will see issues.
But nevertheless, wobble would indicate to me incorrect seating or a larger issue.
HTH
