Eibach Pro-Kit to Tein S-Techs?
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 2, 2010 | 12:12 AM
Dr.Fox's Avatar
2013 C300 4Matic Sport
So...I currently have the Eibach Pro System Plus setup in my coupe - (sachs dampers, eibach pro kit springs, and eibach sways). It came as a kit, and thus all the components work together perfectly. The ride is a bit harsh in the city (NYC streets are terrible, so it's understandable) but since the car is primarily driven daily in the suburbs of NJ, I'm willing to deal with that. The car handles awesome, and is very nicely balanced.
That said...
I have this little fender gap issue with this setup. The rear is slammed, whereas the front is about the height of the stock 230 SS suspension. I really hate that the front of the car appears higher than the back. The one spring set that seems to make the drop appear to have a rake to it is the Tein S-Tech.
I have read many reviews on this forum, from awful to great. Tein seems to be more of a spring for aesthetics rather than performance. While I don't like a harsh ride, I don't want the car to transform from extremely stable and nimble to slushy and scary at high speed. From the research I've done, the spring rates from the Eibachs are quite similar to the Teins, although stiffer than the Teins.
I know this is a decision I'll have to make, but am I making a huge mistake by swapping out the Eibachs for the Teins? Keep in mind, I will have a good set of dampers and sways to accompany these springs too...
Here's a pic of my drop now. You'll see what I mean.
Old Feb 2, 2010 | 12:18 AM
Dr.Fox's Avatar
This shows the drop best
Old Feb 2, 2010 | 01:46 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
You could always keep the rear and just change the fronts.
Old Feb 2, 2010 | 09:08 AM
Dr.Fox's Avatar
I was thinking of doing that, but was advised against mixing and matching springs. I figured it would be ok if the spring rates were close to one another..
Anyone try this?
Old Feb 2, 2010 | 09:21 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Wow, we're almost twins.
Have the same setup as you, and am kind of in the same boat. I hate the front gap, but am afraid to mess with it.
Unfortunately, don't really have any info to offer, other than the same general information you've got. Obviously, you could go coilovers, and get exactly the look you're after; Tein Streets would cost about 800-1k. If their EDFC worked on our cars, I would probably have gotten their c/os, but it doesn't.
Good luck, though - if you have any luck, post results. Used to live in Clifton myself, and the roads around you ain't much better than NYC.
Old Feb 2, 2010 | 09:52 AM
Dr.Fox's Avatar
It's annoying that Eibach couldn't have made the front a hair lower, because you said it - I'm afraid to mess with it at all.
As for the roads, you are right - any main roads here are pretty beaten up - you just have more room to swerve the holes
Old Feb 2, 2010 | 03:31 PM
infected's Avatar
2007 ML500
If you are fussy about ride height then coilovers will be the best solution.
Old Feb 2, 2010 | 04:28 PM
Dr.Fox's Avatar
I think that's probably what i'll do..
Old Feb 2, 2010 | 05:41 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Im curious, how big is that gap really? Can ya take a measurement from the top of the tire to the top of the wheel well? :x
Old Feb 2, 2010 | 07:32 PM
Dr.Fox's Avatar
The gap is right at about an inch. Does anyone know what rear spring pads come on the coupe? Maybe if I raise the rear a tad, it will look more even. If I'm still not happy after that there's always coilovers..
Old Feb 2, 2010 | 09:26 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
The tallest rear spring pad will be helpful I dont think its worth the swap from eibach to tein. I get the impression that they are roughly all the same ride height... Try the rear spring pad first
Old Feb 2, 2010 | 09:29 PM
Dr.Fox's Avatar
Ok. I'm going to try the thicker pads first. It's the best option at this point, I agree - Thanks Tru.
Guess this means I have a brand new set of Tein S-Techs for sale I'll post something up in the classifieds, but PM me if interested.
Old Feb 2, 2010 | 10:05 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
+1 on the rear pads. It did the trick on my sedan anyway (H&R spring set & went from #2 to #4 pads in rear)...
Old Feb 2, 2010 | 10:15 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i agree, just get a thicker rear spring pad and buy tires with wider side walls. The wider side wall should fill up the front gap more and the spring pad should raise the rear a little bit.
Old Feb 2, 2010 | 10:28 PM
Dr.Fox's Avatar
I'm going to order the pads tomorrow and throw em in on the weekend. Its not like the front of the car is high, its just that the rear is so low. Maybe Eibach designed the springs with the thickest pad on the car?
Looks like the pads are the best bet, I'll post some pics once they're installed.
Old Feb 3, 2010 | 01:15 AM
Smallbodybenz's Avatar
2002 c230 coupe
i may be interested in the tein s -techs? send me some info via PM
Old Feb 3, 2010 | 03:50 AM
kirax2's Avatar
I drive a Toyota Hybrid...
o man u don't wanna go lower when you already has spring... otherwise its gonna rub crazy...
Old Feb 3, 2010 | 09:12 PM
Dr.Fox's Avatar
SO...here's the problem. I checked with my dealer today, who ran my VIN #. I was told that my coupe comes with the thickest pads from the factory. Do I have any other options? I suppose if I'm truly going to be picky, I'll just get coilovers. Although I am the car's
toughest critic...Any opinions on the drop? How does it look to you guys?
Old Feb 5, 2010 | 05:29 AM
kirax2's Avatar
i think your current drop looks prefect right now, get a Brabus front lip you won't complain anymore
Old Feb 5, 2010 | 11:30 AM
Dr.Fox's Avatar
Thanks! I think you're right...I was looking at the car from the side from across the street and it really does look good. I think the issue is the front valance doesn't come down far enough on the stock bumper.
Anyone know where I can find a "Frabus" lip for the coupe? I have searched, seems they are quite hard to find these days...
Old Feb 7, 2010 | 04:26 AM
kirax2's Avatar
look up supershyguy he was a member here
http://nextmod.com/index.php?target=...ategory_id=188
Old Feb 14, 2010 | 12:20 PM
BENZ0c240's Avatar
01 c240, 98 c230 & 89 240sx
your issue is the same as mine but dies not look as bad on a sedan. You can look which pad you have by jacking up your car in the rear and take a flashlight and aiming flash light on upper mount .If you see 2 nipples you have #2 pads which from your pics makes me believe you do.
Old Feb 15, 2010 | 01:34 AM
jahoo's Avatar
2002 C230 Coupe 1999 Mazda Miata
Is yours a C7 package coupe? Ours is a Canadian Evolution package coupe and it didn't come with any rear spring pads. The rear had about a 1.5", the front about 3" wheelgap.
I installed H&R springs f/r and #4 pads in the rear and the car had too much rake. Front gap about .75" and rear gap was about the same 1.5". Now with #2 spring pads in the back it looks pretty good, a bit more rake than stock.
Attached Thumbnails Eibach Pro-Kit to Tein S-Techs?-rsz_dsc02371_1.jpg   Eibach Pro-Kit to Tein S-Techs?-dsc00974_1.jpg
Old Feb 18, 2010 | 12:13 AM
Dr.Fox's Avatar
gonna try to get under the car in the next few days to check out the spring pad situation...I don't know what the C7 package is though, but I know I have spring pads. In any case, wouldn't the absence of spring pads have made your car slammed in the rear?
Old Feb 18, 2010 | 04:28 AM
tommy's Avatar
Since he has black door handles, it looks like he doesn't have the C7 package.
Dr. Fox, the C7 package was the $750 package that included color-coded door handles, the 17" rims, thumb rests on the steering wheel, slightly different manual transmission, different pedal pads, and I'm sure something else that I can't remember - it was well worth the add'l $$.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
