Rear Muffler Question
w203 C200K
Hi there,
Does anyone know if a 05+ facelift oval tip muffler would bolt directly onto a preface w203 sedan? Would the rear bar need to be chops for the tip to fit?
I really dont like the standard muffler with its down pipe tips.
Also has anyone had any custom tips made for the down pipe muffler? There are aftermarket bolt on tips but they look terible from a side view.
2013 ML350
O yea, it's been done. If you have the standard two tip turn down muffler, you can go to any competent exaust shop and have them cut the turned part off and weld custom tips on. If you have the standard non- amg type rear bumper, you may have to trim the under portion a bit so you don't get the hot tip to close to the plastic/paint.
You may want to check out this thread as well.
https://mbworld.org/forums/c-class-w...want-know.html
Cheers, Greg
Cheers, Greg
C240
I believe you'd have to get a completely new exhaust. The down pipes are not very workable with bolt on tips.. as they bend!
EDIT: Yeah! Or as said above, cut off the tips..
w203 C200K
Hrmm...
Does anyone know if the standard muffler with the oval yip would directly bolt on, im guessing its diff back?
Heres a pic of how awkward the standard muffler with the down pipes is.
w203 C200K
w203 C200K
w203 C200K
2005 C320 Sport, 2010 C300 Sport
Shouldn't be much of an adjustment. If anything they'll just bend a hanger to drop it 1/2 inch. Worst case scenario, it'll point down, but the angle prob won't even be noticeable.
