Slight "grinding" Sound coming from wheels.
It only happens a low speeds though when Im approaching stop signs.
Any ideas on what this sound could be.
Thanks..
Most likely your brakes need changing
But if you're short on money, you could always use brake cleaner on your pads and rotors, and that may do some good too.
no.. at least change the pads first... had been going low thickness pads and rotors = stopping like ****....
Ill keep everyone posted.
EDIT: I just took it for a drive around the neigborhood. Like I stated before, I can only hear it a low speeds. I hear the sound as I apply the brakes and when Im driving at lower speeds. Im sure its happening when Im driving at higher speeds. Im going to check and see how much I can get the rotors and breaks changed for to see if that fixes the problem.
My rear tyres need replacing (booked in for this week) and I was informed my breaks were replaced when I bought the car a fortnight ago.
For future reference. Michelin PS2 & Exalto PE2 are known quiet tyres on this Chassis. They are all I will use.
Do not use directional tyres. Change rolling direction of tyres every 10,000Km by rotating. Corner to corner with standard wheels. Across the same axle with staggered.
