Hard downshift when braking, especially in W mode
Super Moderator
2007 C230SS; 2014 ML350 BT
I would get the OEM one from RM European for $29.66: http://www.rmeuropean.com/Part-Numbe..._8582EF73.aspx
That was the one listed for 2002 C230 coupe. Make sure you double check your correct part number.
Aftermarket mounts are hit and miss. I have had some fit perfect, and others not so much.
Good luck.
Good luck.
2007 ML350
I think the software fix is it. I bought the URO one from Rockauto (they seem to be okay). I will install it when it arrives, take pics of new vs. old, etc. =) I'll make a new DIY thread instead, but try to link or put pics here too.
2007 ML350
I still have not driven the car enough to know this is IT. However, how does this Differential Mount look? Bad eh? That IS the diff mount, right?
![](https://lh5.ggpht.com/_kFEMcmNchPM/TAMqLg4TYsI/AAAAAAAAApw/EuyweHMiCck/diffmount1.jpg)
![](https://lh6.ggpht.com/_kFEMcmNchPM/TAMqLvUMU5I/AAAAAAAAAp0/cYhvvn-2osY/diffmount2.jpg)
Moving on...
My leaky Diff! On the bar, and to the right and left (see pics below)
![](https://lh5.ggpht.com/_kFEMcmNchPM/TAMqL1iGbvI/AAAAAAAAAp4/5gX3y2Q5B0A/leakydiff1.jpg)
Wet left side... =\
![](https://lh6.ggpht.com/_kFEMcmNchPM/TAMqRWO1oeI/AAAAAAAAAqM/YPk-5Ux1lx4/wetbushunzoom.jpg)
Zoomed in
![](https://lh5.ggpht.com/_kFEMcmNchPM/TAMqRgm7jJI/AAAAAAAAAqQ/XOSJs6zp3bg/wetbushzoom.jpg)
There she is, original trans mount hiding...
![](https://lh5.ggpht.com/_kFEMcmNchPM/TAMqRM-1PZI/AAAAAAAAAqI/7Wnt8MG2KHM/thesetup.jpg)
Removed Engine/trans mount... ick!
![](https://lh5.ggpht.com/_kFEMcmNchPM/TAMqMVWM-qI/AAAAAAAAAqA/qqHl1Bs2a_I/original-mount.jpg)
New Mount! Looks good (Uro mfg)
![](https://lh3.ggpht.com/_kFEMcmNchPM/TAMqL0MkC2I/AAAAAAAAAp8/lHhEI-8g3CE/newmount.jpg)
So how does one go about fixing a leaky diff? I don't think I want to remove it... I've never popped axles before on a car... (avoided).
Advice? I've cleaned it (about 2k miles ago), so this wet is 'fresh' in terms of after a fill.
Moving on...
Wet left side... =\
Zoomed in
#32
Super Moderator
Wow, that mount was hammered ![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
For the diff, it is really hard to tell where it is leaking from with all that oil. What I would suggest is to clean it all off really good, then go for a short drive and see if you can see where it is coming from. I suspect it is the pinion seal.
#33
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Rubbers in general look poor. Why all the corrosion under this car? It it driven on salted roads? Almost definitely pinion seal. The side shaft seal that I can see looks good as does the back cover gasket. Suggest you top up diff & have seal replaced soonest. These axles are strong but not tolerant of low oil level.
Suggest you apply a product like Tectyl to rusted areas to prevent it getting any worse. Any good microfine wax based product with good rust inhibitors will work.
#34
2007 ML350
It was a NY car (salted roads). Actually has some body corrosion (need to ask MB if there is a body corrosion guarentee).
1) Should those rubbers (mount?) be replaced? Cost/R&R on the book?
2) If it is the pinion seal, estimated cost of repair? Is this DIY?
I also did get the harder downshift again, but it seems much less frequent, and never a banger, just 'felt it'. Could actually be normal, but I'm hyper-sensitive (it used to 'bang' sometimes though). =)
Thank you Glyn and johnand
1st, 2006, acceleration, c230, differential, doesit, downshift, downshifting, downshifts, gear, hard, harsh, jerks, mercedes, mode, related, transmission, w203
