Check Engine Light: P2188 & P2190
Old Apr 7, 2010 | 01:44 PM
SkankZ's Avatar
2006 C230 SS
I recently did a service B on my 2006 C230 Sport Sedan. I change the oil with Mobile 1 0W-40. I also change the oil/air/air condense filter.
Now two day later i received a check engine light. The codes are P2188 and P2190. I'm guessing the light came on when i turn the heater on? Since it was one of the possibilities .
I google the codes.. but it is leading me to two different possibilities.
The mileage on the car is almost at 34,000.
Old Apr 7, 2010 | 02:13 PM
e1000's Avatar
a quarter mile at a time
check if you've seated the air filters properly after changing them. They should be snug, and the gasket around the filter should sit in the square hole for each opening.
Old Apr 7, 2010 | 05:19 PM
SkankZ's Avatar
2006 C230 SS
Thanks for the reply.
Would this loose air filter be the cause for my car to idle funny in the morning? When I turn it on it sorta rev up a little then calm down.
Old Apr 7, 2010 | 05:24 PM
e1000's Avatar
It didn't do that before? That sounds normal to me.
Old Apr 7, 2010 | 05:32 PM
SkankZ's Avatar
2006 C230 SS
Oh maybe haven't paid attention until now that the check light Is on
The rev this time.. It rev about 3-4 times by it's self then stop.
Yeah I'll definitely check up on my air filters.
Old Apr 8, 2010 | 10:37 AM
ontmiss's Avatar
2007 C280 4matic Avantgarde
That happened to me few days ago. Remove filters housing and put it back but make sure the rubber seal that goes to throttle body fits nicely.
Old Feb 26, 2011 | 10:55 PM
webking1's Avatar
C230
~50K, my local dealer recommended to change the air filter. I did some research on youtube and found a video ( http://www.youtube.com/watch?v=TT6L9pPf2Fc ) on how to change it. I used K&N filter and it boost performance a bit I think. Make sure you secure the cover with the throttle body! If you don't secure your cover with the throttle body, dirty air could get in and the Engine Light will come on after less than 100 miles driven. If you get Engine Light on, bring it to AutoZone or Advance Auto Parts to check for free. You will likely get these codes P2188 & P2190 (Mass Air Filter -MAF) failure. All you need to do is to reseat it correctly and drive for about 100 miles. The Engine Light should go away by then. I've just experienced this. Dealer wants $800+!
Old Nov 13, 2012 | 09:59 AM
jsohigian@yahoo's Avatar
2006 mercedes C280 4matic
Repositioned, cleared code and light comes back on..
I recently have had the same problem where I took off the air filter housing to inspect the engine must not have put it back on right. Now I am getting these two trouble codes. So, I repositioned inspected it over the throttle body reattached the hose on the airfilter housing, cleared the codes and less than 40 miles later get the same codes again. I think when I initally moved it, and the codes came on it broke the mass airflow sensor somehow?
If anyone can suggest anything, that would be great. I am going to move forward on ordering the new sensor and installing it and see if that works.
Thanks in advance for your suggestions.
Jake
Old Dec 11, 2012 | 08:48 AM
kluvsbenz's Avatar
2014 E350, 2006 C350 Sport(made it to 280k, loved it!), 1990 300E
Jake
I did the same thing when I took the air filter housing off to change the plugs. Now I am getting these same codes-P2190 & P2188. I tried reattaching the air filter housing again. I know it isn't the air filter because I changed it earlier this year and didn't have a problem. The "Check Engine Light" only came up recently after I changed the spark plugs. My indy did mention mass air flow sensor so I am going to have him look at it.
Old Dec 12, 2012 | 12:47 PM
kluvsbenz's Avatar
Thumbs up
***Update***
Just came back from my indy and he ran the Star diagnostic. He said it was the mas flow sensor like he told me over the phone. He wanted to order the part, labor. 400 bucks Not bad but no thanks. I told him to clean it and clear the codes. No problem. Charged me 120 bucks I'll take that. Next time I am going to clean it myself Sometimes that's all it is needed. FYI.
Old Sep 8, 2013 | 08:21 PM
mike roth's Avatar
S430, ML430
What was the actual cure for P2188 & P2190?
Old Apr 1, 2016 | 11:01 AM
mbragus's Avatar
ML 350
I just change my air filter and oil then this code P2188 came out ! What I did was I added a filter screen on the air filter , so now I took it out and drive it for the next few hours and wait for the outcome. Hoping that this will solve the problem.
Old Apr 26, 2017 | 09:31 PM
raykar's Avatar
2014 E350 4Matic
Be sure to press in the four snug tabs of the dual filter housing. If the rear two (the ones nearest firewall) aren't seated then the mass air flow sensor housing has a weak seal with leaks. This will cause your "too rich bank 1/bank 2" codes. This usually happens when you change your air filters. Good luck.
MB 2006 C280
Old Jul 8, 2023 | 10:20 PM
Tecladista 21's Avatar
E 280
p2188 p2190 solution
Revise la lectura del maf sensor, debería estar entre 4 y 6 g/s en rallentí.
