Voltage stabalizer performance.
Subscribe
Apr 8, 2010 | 01:19 PM
I have a hard time believing that 'voltage stabalizers' ( http://www.performancechiptuning.com...Chip+Module/7/ ) can actually claim what advertised as far as performance gain.
Just looking at the device, it appears to be a simple capacitor bank. Even in the description (sorry, gunna break out some electronics jabber) it shows how there is a negative voltage created on the chassis, which is expected if you connect _any_ decent sized capacitor across the terminals. (Actually, in this case, they appear to be smaller capacitors which could provide a 'faster' response than audio-grade (1Farad+) capacitors.)
While capacitors _can_ act as a power filtering/power stabilizer devices, I have a hard time believing that the advertised gains are possible.
So... with all that said, has any one seen modest gains in performance/fuel economy with one of these devices on their benz? If so, I will work out the math with some auto-grade components to let you know how to build one for much cheaper.
Reply 0
Apr 8, 2010 | 01:40 PM
I think the Benz if the first car I've owned where this type of product actually might be of use.
Most cars have very elaborate electrical systems where the voltage is always stabilized. I know on my mazda it was able to hold an exact 13.8 volts no matter what was going on. The Benz however has voltage fluctuating from 12.4-14.4 at any given time.
Now with a cheap device like that don't expect any noticable diffrence. There are $300+ voltage stabilizers that actually work (Ie with voltage regulators). That little plastic box is not one of them.
Reply 0
Apr 8, 2010 | 02:18 PM
I agree. A beefy voltage regulator might be the only way to go. If anything, that little plastic box seems like more of a device to fool a voltmeter, than actually improve performance.
Reply 0
Apr 8, 2010 | 02:21 PM
My company actually manufacturers a good number of these and we've seen pretty interesting gains with the stabilizer used. While it's true that it basically is a series of capacitors set to turn on at certain intervals, this is quite advantageous for vehicles w/ poor grounding and electrical interference. These are also greatly recommended for cars that have had motorswaps because grounding is often an issue after the swap.
We ran a 89$ stabilizer on a 04 Porche 911 Turbo and saw a gain of 16.9 hp. We also saw a gain of 14hp on a Honda Civic (92-95) Hatchback that had a K20 turbo swap. In other cases we saw little gains in the 4-10hp range on cars with better electrical systems (Subaru WRX STi).
One thing we also noticed was that newer cars have these built into the factory system so adding an additional one may not help very much.
--- On a side note, I wrote this because of my experience with them. I'm not trying to sell them. We have a network of distributors for that lol.
Reply 0
Apr 8, 2010 | 02:57 PM
Awesome! Thanks Mike.
Just as a side note, I would avoid using this with a bad ground-loop situation, or you would just have an $89 firecracker... (I have blown up a few capacitors in my time.)
Reply 0
Apr 9, 2010 | 12:38 PM
Quote: My company actually manufacturers a good number of these and we've seen pretty interesting gains with the stabilizer used. While it's true that it basically is a series of capacitors set to turn on at certain intervals, this is quite advantageous for vehicles w/ poor grounding and electrical interference. These are also greatly recommended for cars that have had motorswaps because grounding is often an issue after the swap.
I'm going to need some help understanding whats going on here.
If the alternator is removed from a car and its allowed to run only on battery power. The most I've seen is an 8 hp gain ( that would remove all extra drag on the system)
Adding in capacitors like this could only help to reduce the inefficiencies in the power transfer from alternator to spark plugs. Better grounding = stronger spark and a more stable voltage means a stronger spark. But if the car wasn't misfiring in the first place there should be minimal to no gains. (if it was I can see huge gains). One of these + a hyperground would lead to a much better electrical system, and I might do it just because the electrics on the Benz suck. (Now that I think of it the Porsche has the battery on the other side of the car so I can see gains there.)
I ask because I'm hoping you might know, until now I haven't seen significant gains from such a thing.
Reply 0
Apr 9, 2010 | 02:06 PM
Quote: I'm going to need some help understanding whats going on here.
Honestly, I'm not quite sure on the specifics. What I do know from some general research on the varying brands (like Sun, Pivot, Izuma, NRG, etc.) is that factory systems do have a good amount of fluctuation and drop off in current (one reason car chargers are bad). These systems are designed to level out the current allowing for noise reduction that results in stabilized voltage which then results in optimized power at the coil. Some kits actually amplify power too. Basically though, they're aimed at correcting the pulse noise and voltage drop.
Thats pretty much the most that I know on about it aside from the dyno sheets I've seen. I have seen similar "stabilizers" used on other electric motors to improve performance of the motor but that's probably a different reference.
Reply 0
Feb 24, 2012 | 04:10 AM
Found one on eBay..
Is this stabilizer simmilar to yours? http://www.ebay.com/itm/170525681631...ht_3449wt_1037
Reply 0
Subscribe
Currently Active Users (1)
