4matic rumble. front diff or transfer case
Old Apr 28, 2010 | 02:59 PM
conradf's Avatar
2000 W220 S430, 2015 W212 E350 4matic
2003 C320 4matic, 73000 miles;
I have researched what could be making a rumble during tight turns and am wondering if the noise could be a front diff rather than a transfer case. I am hoping someone can guide me as to what it is.
I purchased the car 6 months ago and the rumble was evident then, although I assumed it was normal, as I have never owned a 4matic. Since I do most MX myself, I have changed all fluids (had an indy replace transfer case fluid due to accesability), plugs etc...the car still makes the sounds at low speed tight turns. It is more noticable in right hand turns and in forward gears and neutral as opposed to reverse.
What makes me wonder about the front diff is that is does this in Neutral. Wouldnt a transfer case issue only be evident while there is a power application and not in neutral or reverse?
thanks.
Old Apr 28, 2010 | 03:53 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
In neutral the car'd be stationary? How is there a diff. noise when it's not moving?
Old Apr 28, 2010 | 03:58 PM
conradf's Avatar
coasting...and then turning in nuetral.
