to go ceramic or non?
Old May 10, 2010 | 11:23 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
Does Akebono also make pads for rear, if so does anybody know the part #
Old May 11, 2010 | 12:49 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I'll have to consider this when my OEM front brakes are worn out. I just replaced the rears at 75,000 miles with new cheap semi-metallic pads. No real dust problem from them, they don't do that much. My car is on its third set of pads and second set of rotors right now. Original pads lasted till 27,000 miles, second set of pads and original rotors lasted until 53,000 miles, and everything is all good for me now at 81,000.
Something interesting:
Through the first two sets of OEM front pads, the brake dust was extreme. When I replaced it with the third set of OEM front pads at 53,000 miles, the dust isn't nearly as bad as it was previously. But these are genuine Mercedes parts. I thought they might have changed something about them?
Old May 11, 2010 | 01:31 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Man, you're hard on your brakes. I'm passing 41,000 miles, and I'm on original pads and rotors, and I really get on my brakes.
Old May 11, 2010 | 02:47 AM
LILBENZ230's Avatar
I bought the car at 25,000 miles and the originals were toast at 27,000 so not my fault there.
At 52,000 last year is when I took myself and four other adults on a 1150 mile trip to FL in the sweltering heat. High speeds, hot temps, the car was VERY loaded, and it just toasted the brakes. The car didn't throw up any pad wear warnings but the rotors were shot after that trip - lots of vibrations. Since the rotors had 52k on them, I elected to replace everything at that time rather than wait for the warning.
The brakes are fine now at almost 81k. These will likely last much longer than the previous two sets.
Old May 11, 2010 | 09:25 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
according to TireRack:
Akebono Euro Ceramic Pads (Material: Ceramic) Product Details | Reviews
Akebono Euro Ceramic Pads Front Fitment
Note: Front brake pads.
Orig. Price: $75.00 (axle set)
$71.00 Special
Estimated Availability: In Stock
Manufacturer Part #: EUR872
Rear Fitment
Note: Rear brake pads
Orig. Price: $67.00 (axle set)
$64.00 Special
Manufacturer Part #: EUR873
Old May 11, 2010 | 10:16 PM
Preet's Avatar
I thought the front pads part # was EUR1121 for Akebono
Old May 12, 2010 | 08:55 PM
  #32
Buellwinkle's Avatar
I did factory pads on my 2004.5 C230 because they don't really dust that much, not like a 2005. But my kid's MB, we did Akebono all the way around, no dust, wearing well after 3 years.
I also like the Pep Boys ceramic ProStop pads I use on other cars like my wife's Jeep (originals lasted 13 months with lots of dust, ProStop Ceramic, no dust, still on there 4 years later) and on a Mustang, stops as good as factory OEM pads which were discontinued. They are well made with stainless steel shims and beveled edges.
Old May 12, 2010 | 09:51 PM
  #33
eddieo45's Avatar
You guys probably install your own. I can't get my FKIA mechanic to use the lube, so they squeaked at first.
Old May 13, 2010 | 01:27 AM
  #34
nrg_mike's Avatar
2005 C320 Sport, 2010 C300 Sport
You don't really use that much of the lube/quieting compound. It should only really be used where the pad seats in the caliper.
Old May 17, 2010 | 01:17 AM
  #35
Cintoman's Avatar
2005 C230WZ SS Capri Blue/Ash
Here's where there's some confusion on the front brake pads from Akebono. I know for sure that my car (2005 C230 Kompressor Sport 4-door) takes teh EUR1121 pads. I heard from several people that the fronts on our cars would be the EUR872 pads. I don't know what the EUR872 look like, but the EUR1121's worked perfectly for my car.
Cintoman
Old May 17, 2010 | 09:17 AM
  #36
Norwichdelta06's Avatar
2007 c230
OEM CATALOG
http://www.showmetheparts.com/akebono/
Old May 20, 2010 | 01:39 PM
  #37
Cintoman's Avatar
Originally Posted by Norwichdelta06
Well, this definitely explains the EUR872 vs EUR1121 confusion for the front brakes. Thanks for posting !!
Cintoman
Old May 20, 2010 | 10:57 PM
  #38
laneshift's Avatar
C240
If you do ceramic, go Akebono. I did those for the fronts and textars for the rears. Fronts haven't squeaked, rears have, even after two sandings of the pads and rotors. The textars are supposed to be ceramic, too...
Both front and rear done within 500 miles.
Old Dec 19, 2011 | 11:50 AM
  #39
drho2004's Avatar
2005 C230 SS
Cintoman
hello, have you experienced any squealing? I have the exact same setup on my front for my 2005 C230K, Zimmerman rotors, Akebono ceramic up front. same part numbers. Changed them both at the same time. Rears are OEM. when i back up there is a pretty loud squeal coming from the front, i thought it might be the rears but i had someone stand outside and sure enough its the front. took them off put some of the brake squeal paste and it still does it. not when i go forward just when backing up. but hey, one good thing NO BRAKE DUST!
Old Dec 19, 2011 | 02:01 PM
  #40
2007 c230
I thought it was just me! Lol.my squeak only when backing up
Old Dec 19, 2011 | 05:28 PM
  #41
2007 c230
I have akebenos up front and rear.. Balo's front and rears.. I bought ceramics because in the past they leave less dust and dont squeak at all. It might be your rear brakes honestly. OEMS are semi metallics
Old Dec 19, 2011 | 11:45 PM
  #42
Cintoman's Avatar
No....no squealing at all, going forward or backwards, slow or fast. I've had my Zimmerman rotors and Akebono ceramics on my car for about 24,000 miles, and have had no issues whatsoever with them. I'll be doing the rears come springtime as they're getting thin.
Cintoman
